I've been trying to reflow FMC connectors (Samtec ASP-134488-01) with mixed success on a skillet.
These connectors have a solder charge (
), a little like a BGA: they come with pre-formed solder caps on the terminals, but rely on the flux in your solder paste to wet them during reflow.
These connectors are thorny for a few reasons:
- They're nearly un-inspectable and totally un-reworkable, since they're underneath the connector body
- There are 160 pins per (LPC) connector, and "most" of them need to work
- They're physically large, so any bowing or twisting of the underlying board will ruin my work
I've played with the soldering profile ("twiddling the dial on the skillet while holding a stopwatch") and dabbing flux on the part before putting it on the prepared board. I am still not getting reliable results. I am going to look at the PCB footprint today to see if it's a problem with pad sizes.
Before I throw up my hands and have the part reflowed elsewhere, I figured I'd ask here for suggestions. Please?
Moreover, should I expect the bargain assembly houses (pcbway) I'm considering to do a 100% reliable job on connectors like this? Or, am I trading my own dubious reflow for someone better-but-still-not-good-enough?
