Author Topic: Looking for Free Sheetmetal forming software  (Read 3615 times)
Offline connectTekTopic starter
« on: March 11, 2023, 08:31:05 pm »
G'day Guys
Has anyone got experience on any decent free software to make metal/ Aluminium enclosures?
I have a pan and brake and would like some software that helps with design.
Cheers.
Offline loki42
Re: Looking for Free Sheetmetal forming software
« Reply #1 on: March 11, 2023, 10:18:39 pm »
I use fusion 360 for the cad section but they don't have cam for sheet metal.  If you want to know if the dies / punch you've got can form the part without interference you'll need something else. Should be fine for most pan stuff though.
Offline phil from seattle
« Reply #2 on: March 14, 2023, 02:33:30 am »
F360.  The sheet metal module works great. create the object and then flatten it out. Lots of good tutorials out there. I believe you can get a DXF from that or use it as a sketch. I've usually just cut the sheet metal by hand, though.
Offline MR
  • Country: tw
« Reply #3 on: March 14, 2023, 08:54:27 am »
FreeCAD also has a useful sheet metal workbench.
However be careful with complex designs, FreeCAD does not perform well on complex objects (and always make backups).
Offline loki42
« Reply #4 on: March 14, 2023, 11:17:51 am »
Do any of them have cam?  I really like to know if I can make stuff with the tooling I've got or I'll need a different shape punch to not collide.
Offline MR
  • Country: tw
« Reply #5 on: March 14, 2023, 12:07:25 pm »
FreeCAD has, to a certain degree. F360 too, but it doesn't do rapid moves as far as I know in the free version. However if you do something serious a subscription should be worth it.
FreeCAD is more difficult to learn, and more complicated in some areas. F360 is more efficient I would say (I'm mainly using FreeCAD though).
« Last Edit: March 14, 2023, 12:11:58 pm by MR »
Offline loki42
« Reply #6 on: March 14, 2023, 12:37:38 pm »
Oh I haven't found any press brake cam in fusion 360 before.  Handy if they've added it.  I'd like something the can work out the bend order and if it needs a goose neck punch etc.  Exporting in amada format a bonus.
