So after 3 months of arranging, getting power and air connected, levelling, buying greases and oils, levelling more, cleaning a lot, replacing a few parts and learning a lot (slowly) about the machines they actually run.
The stencil printer (MPM Accela) was a bit of a nightmare to get working but it's running now. It still sometimes randomly doesn't have a working camera when you turn it on but restarting it fixes that and once running it runs all day fine. The results from the inspection and it in general are very good. I started with just dry under stencil wipe, then realised the vacuum options which is a huge improvement. The input air filter and one conveyor input sensor were the only thing that was actually broken on it, otherwise things just needed oiling and repositioning.
The Universal GC30 is working smoothly. One of the air cylinders that opens one of the nozzle changers leaks air so it'll need a new seal at some point. Board support pins weren't included and are vital for any thin or large boards. I suspect they are a good idea for all boards. I've made some sheet metal board supports on my press brake and they seem to be working fine but I might see how much the manufacturer ones are. Oh and width control doesn't work properly but I can live without it... it would be nice though.
The GX11 is working well for 1 of the heads (4 spindle high force) the 7 spindle head currently needs calibration I think. It complains about nozzle collision when it performs a nozzle change or when it picks up a part. I can survive without it though as I'm just using the GX11 for large parts and the 4 spindle head works fine for that. It'd be nice to get both heads working though.
Essemtec Ro300FC needed a few bits changed and replaced to work in Australia but it's now running smoothly.
I haven't set up the AOI yet, currently the Accela does solder paste inspection and I run the universal machines in NPI mode on the first board and check all the placements by hand for the first board and glance at later ones. I haven't got validation (PSV) setup yet because the docs were pretty confusing... if anyone knows how the bar code stuff is meant to work I'd love to know because currently it doesn't. I'm using gold feeders with PSV tabs.
Oh and if I was looking for a new machine I'd look for feeders that had proper sized handles...
