Author Topic: Low viscosity potting compound for electronics  (Read 2434 times)
Offline dimbmwTopic starter
« on: November 03, 2022, 01:58:51 am »
Hello everyone
I’ve seen it many times on some electronic boards I’ve repaired over the years, a clear jelly- like sticky substance.
What is it and where can I buy it?
I need a stuff with very low viscosity to fill some narrow areas as well as all the volume where the PCB is located.
Thank you!
Offline andy3055
Re: Low viscosity potting compound for electronics
« Reply #1 on: November 03, 2022, 02:31:39 am »
On a site like Mouser, search for potting compound. You can check the spec sheets and go from there.
Online Kean
    • Kean Electronics
« Reply #2 on: November 03, 2022, 03:57:06 am »
The clear "jelly" stuff that I have used is called Magic Gel from Raytech.  https://www.raytech.it/
It isn't low viscosity though.  Nor is it cheap, but not many good potting compounds are.
Edit: The Magic Gel datasheets do state "low viscosity" - so check the specs to see if it is suitable for you.
« Last Edit: November 03, 2022, 03:58:40 am by Kean »
The following users thanked this post: dimbmw
« Reply #3 on: November 05, 2022, 06:12:59 am »
Thank you, could you suggest what is it’s approximate shore A hardness when it dries?
There are no viscosity numbers in the specs… but it looks very liquid on video.
10 min working time is very short …
Online Zoli
  • Grumpy old men
« Reply #4 on: November 06, 2022, 04:52:03 pm »
Hello everyone
Thank you!
Tough-seal fits your description, but: black, and cured is rubber-like-consistence; it has ~1h working time, available in 50ml cartridge to try out(dispenser & mixing tube recommended for partial use).
