where do you run your leader tape ? over the the little brass tab that it shows in the manual or behind it, we've tried both over the years and have had better results not routing it like the manual shows , curious if others have tried doing it that way?
it seems to lift too much and can cause a skip off the teeth, i mean almost everything in the neoden causes that, but one at a time (never mind all the additional weights)
cheers
