So... you offer essentially the same PCB service as Seeed and Itead, but at a significantly higher cost ($26 vs $10 for 10pcs 5x5cm)? Probably using the same factory they use, given the packaging and specs?
... That's not very impressive.
As for the membrane switch service, any pricing examples? For custom setups (obviously), in low quantity. I'm vaguely interested.
