> im quite suprised by the robustness of your vision algorithms
Not mine:
http://www.aforgenet.com/framework/ > components not being exactly straight in the tape
That error is smaller than what surface tension corrects at reflow.
> you want to decrease the setup time to be low enough that it makes sense to use it even with smaller boards and less frequent work.
I think I'm there as far as setup goes.
You need to get the parts out of your storage on your work area, there is no way around that. With the machine, you put them down with double sided tape by a ruler and a couple of mouse clicks tells the machine which tapes are where.
Of course, the software can be improved to no end. the hardware first revision is done, so this will be the focus for next few months. (First on the todo list: Speed improvements, small pitch IC placement, BGAs)
