Its not that its new or not, the jank factor is off the charts.
Clearly a reused case from another instrument, loose 18650 cells taped together with cheap yellow tape, random soldered and taped wires hot glued in place, no heatshrink used. The wallwart could even be transformer based.
And they supposedly have 998 pieces on hand, right.
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/xgrin.gif.pagespeed.ic.QVVz6XIT20.png)
