I owned both the T937M and also the RF-A250 (or ZB2520HL). The Zhengbang unit built quality is very much better than the Puhui's. The Puhui unit is very flimsy. The infra red tube in the oven has a metal cage around it that reduces the direct heat which is missing on the T937M. So, if you are reflowing plastic parts like JST connectors, they melt like candies in the T937M but will be okay in the ZB2520HL with some tweaks on the profile.
But, what I like more on the T937M is the way they implemented the profile which follows your profile very much closer with the climb rate accordingly.
The ZB2520HL on the other hand, is just a ramp-soak-ramp PID controller, so it stays at a temperature set point for some time before moving on to the next setpoint.
However, both units effective area for lead free is much smaller than the physical size available. So, size up to the next higher power unit if you think you need to reflow larger PCB.
The T937M is very hard to service and if you need to replace the tube, you basically have to tear down the entire unit (unlike the smaller and simpler T962).
But, I still think a hacked toaster oven have a much better solder quality albeit the size can be a limitation. Too big toaster oven just won't work.
