Author Topic: Rigid-Flex  (Read 5165 times)
Offline robotix3Topic starter
Rigid-Flex
« on: June 20, 2017, 05:34:37 pm »
Is there a basic cost multiplier of a rigid-flex board vs just a simple rigid PCB or a simple flex PCB?
I have never used rigid-flex, are there any caveats that I need to be aware of (or any good whitepapers I need to read)?
Thanks!
Offline Yellofriend
  • Country: hk
Re: Rigid-Flex
« Reply #1 on: June 20, 2017, 11:31:34 pm »
The cheap way would be to use a rigid PCB, and a flex PCB and have them connected via a FLZ connector. Will be way cheaper!
They can be with or without lock.
TVM802C - now with OpenPnP
T962A
Re: Rigid-Flex
« Reply #2 on: June 21, 2017, 12:40:39 am »
We want to avoid using connectors due to having sensitive analog lines.
Offline mrpackethead
  • D Size Cell
Re: Rigid-Flex
« Reply #3 on: June 21, 2017, 01:40:01 am »
pcbway.com do them, quote it online.  Will give you an idea.
Offline thommo
Re: Rigid-Flex
« Reply #4 on: June 21, 2017, 04:13:04 am »
Actually, Mr Packethead is 'mostly' correct - PCBway actually do RigidFlex, BUT their Online Ordering system is only for Flex PCBs.
You will need to upload your file via that GUI and place implicit instructions for them to contact you regarding details PRIOR to commencing production. They will then send it out and return a quote for you. Their Flex PCB cost is very reasonable.
Re: FFC connectors - we currently use connectors [28way, low profile, 0.5mm pitch], but require the board space for other things now, hence the move to RigidFlex. We will still need to use a connector on the 'other' side however.
I'm not certain who they use for their RigidFlex manufacturing, but we are about to shortly discover what their product is like - in the next week or so.
There is a stack of info online, and most of it is both contemporary and consistent. Wurth also produce a RigidFlex Guidebook which is great value.
Good luck - Peter
  • D Size Cell
Re: Rigid-Flex
« Reply #5 on: June 21, 2017, 04:58:54 am »
Wurth make arguably the best pcbs you can get.  But they come with a price point that precludes anyone who doe'snt have moonbeams and vaults of gold.
Offline noras
  • Country: tw
    • PCB star page
Re: Rigid-Flex
« Reply #6 on: June 21, 2017, 06:22:46 am »
PCBWay Rigid-Flex only one option in the PCB, there is online pricing only rigid part price, and online calculation only flex board,So I recommend http://www.eevblog.com/wiki/index.php?title=PCB_Manufacturers to find the rigid-flex board.Please provide information about the desired type, dimension, quantity, etc.
« Last Edit: June 21, 2017, 06:37:11 am by noras »
Offline noras
  • Country: tw
    • PCB star page
Re: Rigid-Flex
« Reply #7 on: June 21, 2017, 07:01:52 am »
rigid-flex board: the main in the flex part requirements higher
Two inner layers of BASE are pressed
Sandwich practices do inner lines
Pressure L2 / L3 protective film
Preload two outer layers of glue
Stacked two outer layers after laminating
Secondary drilling
Copper plating
Outer DES
A protective film for pressing the outer layer
Superposition:
Offline Jeffpcb
  • Country: cn
    • Shenzhen Vip Circuit Co.,Ltd
Re: Rigid-Flex
« Reply #8 on: June 21, 2017, 07:37:58 am »
Maybe you could share an opportunity with us ,let's see how can we help you!
Vip Circuit from China,serve attentively,quality dedicated
www.vipcircuit.com/
[email protected]
I am a Sales engineer with professional experience from Vip Circuit-Leading PCB manufacturer,meeting your any kinds of PCBs requirements,exceed your expectation!
[email protected]
