Hi - first time caller, long time listener.
I need a board/device, to power a ring of about a dozen or so LEDs, that will light in the direction it's tilted.
So if I tilt the board forward, the 12 o-clock LED will light (and optionally the 11:00 and 1:00 LEDs will be dimly lit).
Think of it like a hat for a radio controlled hoverboard, that lights the direction in which it's tipping.
I've found the LSM303 Arduino board, but I hope I don't need to build this from scratch. Seems to me there should be something like this I can buy off the shelf, or one that's prebuilt but needs some tweaking. Worst case I might need to tweak/add functionality (e.g. a kill switch if it goes into a spin, or at startup, light the north-facing LED...) so maybe COTS and a little programming or Fiverr or something.
Any guidance is appreciated!
