Author Topic: TO247 insulated heatsink mounting kit  (Read 1422 times)
Offline FaringdonTopic starter
« on: June 28, 2022, 09:10:38 am »
We need to  screw a TO247 NFET to this heatsink (MC33271)...(FET insulated from heatsink)
MC33271 heatsink
https://uk.farnell.com/multicomp/mc33271/heatsink-to218-220-247-2-7-c-w/dp/1710614
Do you know of specific TO247 thermal pads?...all seem to be TO220
Theres this at 1.7W/m-k and 0.3mm thick
https://www.digikey.co.uk/en/products/detail/t-global-technology/TG-AL373-20-20-0-3-0/3042275
...most offerings have (unwanted) adhesive on one or both sides, are too thick, with way too much voltage isolation, and are all the wrong size for a TO247....~14mm x 14mm. (however, we dont mind a bit of overhang, and can trim them down)
« Last Edit: June 28, 2022, 11:46:46 am by Faringdon »
'Perfection' is the enemy of 'perfectly satisfactory'
Online mariush
The following users thanked this post: Faringdon
Online MarkF
Re: TO247 insulated heatsink mounting kit
« Reply #2 on: June 28, 2022, 01:44:00 pm »
I don't use them.
I isolate the whole heatsink instead by placing unconnected pads for the heatsink posts to provide structural support.
And don't run any traces under the heatsink on the top side.
It's probably a bad idea for high frequency stuff.
But, it gives a slightly better heat transfer without the insulator in power applications.
« Reply #3 on: June 28, 2022, 02:14:12 pm »
Thanks, we will try and get away without  shoulder washers, and hope the TO247 "insulated hole philosophy" will help us.
Good idea about just leaving the heatsinks floating....the fear of noise worries me , but i bet it would have been fine. Too late now, board is layed with HS to local ground.
Online langwadt
« Reply #5 on: July 20, 2022, 01:09:12 pm »
Thanks...
So I have purchased the attached, 20mm x 20mm TO247 thermal pads…
Digikey part no.
1168-TG-A482K-20-20-0.1-0-ND
In the Digikey photo,  and the datasheet, it just appears to be a red pad, but as the photos show, it actually has like a clear plastic backing. Is the red bit supposed to peel away from this clear plastic backing? ..if so it  wouldnt be easy to peel away.
Digikey page of thermal pad
https://www.digikey.co.uk/en/products/detail/t-global-technology/TG-A482K-20-20-0-1-0/4385400?s=N4IgTCBcDaIC4HMC0BDALADjAayWADHofiALoC%2BQA
« Last Edit: July 20, 2022, 01:11:14 pm by Faringdon »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: July 20, 2022, 01:35:26 pm »
Remove all carrier film before application.
Seven Transistor Labs, LLC
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #7 on: July 20, 2022, 01:35:50 pm »
Try this pad:
https://www.tme.eu/en/details/wk_247/heatsinks-equipment/fischer-elektronik/wk-247/
It's one sided slightly adhesive for ease of application, comes on roll, hole precut.
or this oxide plate, gives better thermals and insulation at higher cost and thickness:
https://www.tme.eu/nl/details/aos218_247_1/radiatoren-uitrusting/fischer-elektronik/aos-218-247-1/
AAVID thermalloy/Boys sells similar parts, just look it up in their catalogs. For the americans.
Edit: non adhesive also available https://www.tme.eu/en/details/ws_247/heatsinks-equipment/fischer-elektronik/ws-247/
« Last Edit: July 20, 2022, 01:38:39 pm by Jeroen3 »
« Reply #8 on: July 20, 2022, 07:30:58 pm »
There was some film on it, which i removed, but the clear plastic sheet thing appears very strongly adhered to the red bit......it doesnt seem to be removeable at all, i tried "widgering" it with a scalpel blade edge, but i just couldnt get it off the clear bit.
