Author Topic: Weller WX serial protocol  (Read 4738 times)
Offline owieccTopic starter
    • Google scholar profile
« on: June 09, 2020, 04:56:09 pm »
Anyone got a clue what the serial protocol is for the WX stations? I only found this post at dangerous prototypes, but in true internet fashion they say they have the protocol but do not post it >:(. I cannot find anything useful on Weller's website.
My WX2 died. The display backlight turns on and that is it. I want to connect it to a computer and see if it is still alive and only the display died. I emailed Weller about service - no answer.
Offline phil from seattle
Re: Weller WX serial protocol
« Reply #1 on: June 09, 2020, 09:05:01 pm »
from the DP thread, it looks like it's a serial protocol.  That should be pretty easy to sniff out if you can't find the actual protocol definition. I'd check it first with an Oscope to see if it's really RS232 or just async (logic level). I'd bet the latter.
Offline ehagerty
« Reply #2 on: July 29, 2020, 07:37:02 am »
Hi, first post so forgive me if I lack correct etiquette.  I don't think I can legally give you their document, but if you google "weller Application Note: WAN12-0006" that's what you are after.  I spoke with their AMAZING tech support and they sent it right over - such awesome people at that company IMO.
What I don't yet know, but have asked, is if you can interface via the USB bus or have to use the RJ11 on the back of most units - which is what the serial chip is attached to.  IIRC it is an analog devices ADM3251E or similar.
If you do anything interesting with the comms do post it as I'd love to know what you learn.
The following users thanked this post: meshtron
Offline ehagerty
« Reply #3 on: July 29, 2020, 02:13:03 pm »
Just a follow up - you must use the RJ11 port on the rear - although they are working on a USB interface it isn't part of the current product line.
Offline kubark42
« Reply #4 on: December 13, 2023, 01:47:27 pm »
Found easily thanks to @ehagerty!
The following users thanked this post: girts
