Thinking I'll shell out for a turning holder too as this fella seems to have a 2nd screw for geometry adjustment:
https://www.ebay.com/itm/284645720497
To best match the lathe tool post I need 25mm shank tool holders which does unfortunately push into another price bracket.
That is not geometry adjustment screw in the pics, just another clamping screw to keep the insert and/or shim firmly in the pocket.
Thanks for this confirmation as I did wonder if it was for additional clamping, something plain turning inserts don't need in my experience...which is somewhat limited.
In case it wasn't already clear: Typically you don't need to fool around with the angled shims with any of the standard threads. You need one only if you make something with really high helix angle like super-coarse thread outside of standards or multi-start thread.
Yes, deeper study of the Hoffman PDF from Benta reveals the charts indicating which pitches you can turn without tapered shims....most normal stuff as you say.
You can use compound or cross slide, sort of depends on machine and personal preferences.
Earlier I was using combination of compound and cross slide as it makes math/counting really easy(increase depth of cut only from compound slide and never retract it. And use crosslide to retract the tool at the end of the cut but set it at same position before each cut)
Later on I installed 2-axis DRO and moved to using only cross slide as compound slide didn't have DRO scale and it was easier to work with the DRO numbers alone.
All my threading thus far has been increasing cut depth with the compound slide and backing out and in with the cross slide.
Many years back I watched a professional machinist thread stepped bolts to a shoulder and into a relief to stop the lathe with the leadscrew nut engaged, bact the tool out with the cross slide then reverse the lathe and tool along the thread to stop it again, return the cross slide to zero and advance the compound for another pass.
This ^ stuck in my mind for decades until I had I had a lathe capable of threading and finally owning a fish tail threading tool.
When pressure came on to put all this together for rifle barrel threading to fit a suppressor, practice on a scrap of round stock had me get it right right from the get go and no one was amazed as I was that a small and seemingly useless bit of technique had stuck fast in my grey matter all them years !
And unless you have huge collection of tooling with 25mm shank you can also use smaller QC toolpost. Just set the toolpost higher with piece of steel disk or plate. (have to be flat and smooth but since you have lathe you can always turn it flat)
25mm shank tooling is not giving much advantage in home shop use unless you work on really large parts and heavy cuts like turning 1:1 scale steam locomotive axles.
Good toolpost in >16mm shank sizes is plenty of rigid for threading with carbide. Typically the ridigity problems are somewhere else.
Current 4 sided tool post in use is a 4" beast which IIRC can take 27mm tooling so 25mm tooling works well with it although I still need shim tools a little.
It replaced the smaller 3" tool post that came with this Harrison lathe which couldn't accept 1" tooling and the 4" beast I like better for a few reasons.
The most shimming I need do is for a small 14mm square shank bar I made to do small boring between 1/2 and 3/4" where my bigger bars take over.
This lathe does show some signs of wear and gib tightness is a compromise but sometimes needs addressing especially for parting where any chatter is a recipe for disaster.
Thanks chaps, really enjoying the feedback.
