Author Topic: RS232 readout on cheap DRO?  (Read 929 times)
Offline maxwell3e10Topic starter
« on: October 06, 2022, 07:47:41 pm »
I have a cheap DRO "SNS-2V", is has an RS232 port but I can't seem to get any response from it. Also couldn't find anything in the manual besides how to set the baud rate. Has anyone used RS232 port on one of these? What are the typical settings and commands?
Offline thm_w
  • Non-expert
Re: RS232 readout on cheap DRO?
« Reply #1 on: October 17, 2022, 11:34:00 pm »
Send every character to it yet? Some other manuals state to send STX.
Take it apart and look at the board to make sure its populated?
Put a scope on the Tx line?
Online ledtester
« Reply #2 on: October 17, 2022, 11:46:35 pm »
I found this manual:
https://www.trabiss-int.com/wp-content/uploads/2018/12/DS-2V-and-DS-3V-English-instructions.pdf
which appears to be the manual for this aliexpress listing:
https://www.aliexpress.us/item/2251832719664379.html
Note the similarity of the user manual cover:
1617191-0
On page 12 there instructions for setting the RS232 baud rate.
Don't know if this manual is the one for your model, but it looks like it might be.
Offline thm_w
  • Non-expert
« Reply #3 on: October 18, 2022, 12:57:16 am »
Yeah OP said they found how to change baud. Nothing else in there about printing out info.
Actually, any chance they are using the wrong cable and need a null-modem cable? seems unlikely though, most cables are standard M-F or whatever.
The following users thanked this post: ledtester
« Reply #4 on: October 18, 2022, 01:15:42 am »
Yes, that manual online matches more or less the printed manual that I have, and I can change the baud rate. I tried sending a few random characters, but not STX. Will try that magic word. Also will try to trace the wires to be sure which one is T and which is R.
Offline Doctorandus_P
« Reply #5 on: October 22, 2022, 10:27:09 am »
What is the end goal you want to achieve with this?
A reminder that the glass rulers that connect to a box like this produce simple quadrature signals and are easy to interface, especially if you use a microcontroller with integrated quadrature hardware.
Software examples are also common, as the same signals are used extensively from simple manual rotary encoders (such as oscilloscope and power supply knobs) and encoder disks on all sorts of motors.
