Author Topic: Why is drill bit Nachi so special and expensive?  (Read 1202 times)
Offline abdulbadiiTopic starter
« on: January 12, 2023, 05:19:04 pm »
What makes drill bit Nachi so special and expensive, what's its Europe or US-made rival?
Offline TimNJ
Re: Why is drill bit Nachi so special and expensive?
« Reply #1 on: January 12, 2023, 08:20:47 pm »
Not sure about Nachi. Never used them.
There are many: Viking/Norseman, Chicago-Latrobe, CLE-LINE, Hertel, Guhring, and so on
Online thm_w
  • Non-expert
« Reply #2 on: January 12, 2023, 10:48:49 pm »
You need to be more specific.
It looks like they make some specialized tools and grinds for specific materials and applications: https://www.nachi-fujikoshi.co.jp/eng/tool/drill/index.htm
But in general, the longer a bit lasts the more expensive it tends to be. Automated machine shops want their tools to last very long to reduce the need for human intervention, and ruined parts if the bit breaks, etc.
You can find some consumer grade bits here:
Online beanflying
« Reply #3 on: January 12, 2023, 11:32:51 pm »
If you need to ask that question likely you really don't need to spend that much  ;)
Generic swill Jobber length drills are nothing like high speed CNC drills are nothing like those used on more conventional manual Mills and Lathes. All of them have a place and a use case depending on method and material you want to go through and how often and how fast.
For example as a home user buying a Nachi 1/4" Jobber style drill over a more generic HSS/Cobalt drill off Amazon to drill a dozen holes in 1/4" steel plate with a cordless drill would simply be nuts. If on the other hand you wanted to make 100 holes in 1/4" Hardened Steel in a CNC Mill then no way would you even look at Amazon grade drills.
I brought a small expensive set of Tungsten Carbide stubby drills (3-8mm) for my CNC Router recently so I could drill Steel and Cast Iron on the High Speed spindle (20k RPM running around 5k) as anything much else would get burned up or you would be rubbing the cut generating heat in the material at the very bottom end of the spindle speed range.
So spend it if you need to otherwise buy 'fit for purpose'
The following users thanked this post: abdulbadii
Offline EPAIII
« Reply #4 on: January 13, 2023, 10:23:51 am »
I have a machine shop in addition to my electronics benches and I have over a dozen sets of drill bits, in addition to individual sizes I purchased for special reasons or just as replacements when the ones in use get dull or break. I had not heard of the Nachi brand and that alone is a clue as to why they are expansive. Their bits are not a "commodity" type item in every hardware store and Walmart. They are a high end supplier. Higher quality and lower volume means higher cost.
There are many possible differences in cutting tools. The alloy or material they are made with. High speed steel (HSS) bits are the most common, but even they come in a number of different alloys. Then there are carbide bits which can last longer but also break more easily (ask how I know). You can even get diamond bits. Then there are coatings that can be applied. And more geometries that I can even count, some of which require special (expensive) grinders. Number of flutes, helix angle, rake angle, clearance angle, tip angle; it goes on and on. Some drill bits even have holes in the flutes that carry a cutting fluid under pressure from the shank to the tip for constant cooling and to flush the chips away. And of course, different quality levels. If you examine a high quality bit and a hardware store bit side by side, under magnification, you will see a world of difference.
After looking at their web site for a few minutes I got the impression that Nachi makes high quality bits of many different materials and geometries. I suspect they cater to the professional machining trade. Perhaps they even have sales people who make regular calls on the professional shops which use a lot of drill bits. Free lunch and all that. I did not see any prices, but I suspect they are high.
I would say that if you do not have a definite, specific reason for purchasing their bits, then you will probably be well served by just ordering from one of the wholesale machine shop supply companies. They will have very good quality drill bits in a variety of types for many different purposes. MSC is one such supplier in the US. Also McMaster sells good quality tools. Both of those companies sell good to high quality drill bits. I can name others if you like. If you are having problems drilling holes, post more information on that and suggestions can be made.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Offline Kalvin
  • Embedded SW/HW.
« Reply #5 on: January 13, 2023, 10:33:08 am »
A video of how to use cryogenic treatment of drill bits to prolong their lifetime.
The following users thanked this post: Overspeed
