For my experiments with the 32-Bit-ADC-chips LTC2508-32 and AD7177 i want the best possible reference one can build at home.
Since the chips only accept maximum 5Vref one can use a LTZ1000 but has to divide the 7.2V down via high cost resistors or via capacitor-dividers (or via transformers...).
Since the LTC1043 capacitor-building-block-ic is said to be very long term stable and inexpensive i used this road.
An attempt on blueprint-board with the following circuit: LTC2057-buffer -> LTC1043 / 3 -> LTC1043 * 2 -> LTC2057-buffer delivered sufficient ~4.8V at ~1µVpp, while the 7.2V from the LTZ1000 came from a separate KX-Board.
See also this thread for more info:
https://www.eevblog.com/forum/metrology/ltc2508-32-bit-adc/msg1727468/#msg1727468Since it works i now want to design the LTZ1000 and the whole buffer/divider-stuff on one board, based on the LTZ-reference-board suggested by Dr. Frank.
See this thread were he shows his board:
https://www.eevblog.com/forum/metrology/mx-reference/msg1297126/#msg1297126I chose this board as a basis since it follows all suggestions for a nice and quite reference-design:
-all components THT, therefore one does not need to fear microphonic effects, humidity/temp-board stress
-star-ground
-good thermal design
-foil/PWW-resistors usable
Dr. Frank was so nice to send me his board-files so i can modify his board directly. Thanks again for that.
In the attachment you find my early attempt to layout the board, please critize it and tell me were i can improve it. After successful tests the board will go Open Source.
A few words and thoughts about the board and changes to Dr. Franks-Layout:
-the following components arent in the original LTZ1000-schematic from the manufacturer: C6/C5/C4/R6/R11, Dr. Frank and Andreas designed them in due to measured spikes, i left them in the design so one can still populate them later if needed
-LTC1052-buffers with lowpass at the input to dampen chopper-spikes, should be able do safely drive the 1µF-capacitive loads, but i didnt find a manufacturer-suggestion for a capacitive-driver-design
-CD4060N and 4MHz-crystal produce the 500Hz-clock to synchronize the two LTC1043 so one gets the low 1µVpp-noise, but its also possible to populate C9 and C10 and depopulate R16/R14 and let them run independently
-im thinking of stuffing the 500Hz-generator (CD4060N and crystal) into a small separate shielded case and connect the 500Hz-clock via SMA/SMB-connector, this would shield the board from the 4MHz-crystal, which might add noise?
-i tried to design a good star-ground, but maybe my solution is not sufficient?
Thanks,
Echo
