Author Topic: Building your own voltage reference - the JVR  (Read 210172 times)
Offline EC8010
Re: Building your own voltage reference - the JVR
« Reply #350 on: July 11, 2023, 04:30:16 pm »
Perfectly happy to make an oven - I've previously immersed components in oil. (Top tip: Use silicone sealant intended for engine assembly or oil seeps through tight threads.) I have plenty of J111, so I'll bin some for VTO to find a reasonable pair for the cascode. Been wanting to make a Peltier device do something useful for some time. Previous experience is that they need a huge heatsink to be effective.
Surprised that humidity should be a problem with epoxy packages, but if you've measured it... And absolutely mystified by your used rather than new desiccant recommendation! Please explain.
I thought I remembered something about JFET references in AoE 3rd Ed. So I looked it up (p680). This is where the IC manufacturers have a serious advantage. AoE describes a two FET reference where the voltage difference between two FETs of identical geometry but slightly different doping is measured by an op-amp, thereby reducing the tempco.
Online dietert1
  • Country: br
    • CADT Homepage
« Reply #351 on: July 11, 2023, 05:29:53 pm »
Last automn i put dry desiccant into a glas with rubber seal, together with two NOMC resistor arrays (plastic package to test) and a meter. Until february the meter showed 0 %RH (out of range). Now it reads 2 %RH. To get equilibrium near 50 % one may have to wait many years. If you use "invalid" desiccant instead, the humidity difference between inside and outside will be less. With a difference of 10% instead of 50 % the expected drift within a year would be a fraction of 1 %RH.
Regards, Dieter
Online Kleinstein
« Reply #352 on: July 11, 2023, 06:29:17 pm »
The peltier elements need a large heat sink only for cooling. For heating they are perfectly OK with a relatively small heat sink, though a reasonable large one still helps.
For the relatively small and low power JFET based reference a simple oven based on heating alone is fine, especially if a more moereate temperature like 40-50 C is used.
With the linear TC reasonable trimmed the oven does not have to be that accurate or stable. Against the square part even a rather crude oven is quite effective.
Offline iMo
  • Country: li
« Reply #353 on: July 11, 2023, 06:30:00 pm »
Is that The "Special Reserve Kaluga Huso Hybrid Caviar" or the "Beluga Hybrid Caviar" in that jar?
Online dietert1
  • Country: br
    • CADT Homepage
« Reply #354 on: July 11, 2023, 07:01:17 pm »
No caviar here. The desiccant (orange when fresh, green when invalid) turned black when drying in the oven. The theory with "invalid" desiccant is to have a buffer that absorbs and yields humidity.
Regards, Dieter
The following users thanked this post: EC8010
Offline EC8010
« Reply #355 on: July 11, 2023, 07:11:48 pm »
Used desiccant obvious once stated. Now all I have to do is to find some. I'd rather gently heat a small oven using a TO220 resistor. In fact, I'll just make it a bit of 6mm thick aluminium with some 4.8mm holes for the JFETs, epoxied in place and an NTC buried in a little hole with more epoxy. With only a little mass, not much power will be needed. I've just measured rather a lot of J111 for VTO at 20nA. Looks like -8.2V to -8.4V is the most popular bin, and I saw quite a few -8.25V devices. Tomorrow, I'll look for matches within that bin. Because the VTO is so high, they won't have a particularly high mu, but that can be surmounted by making a triple cascode. Probably need 24V rather than 12V to power it.
Online Kleinstein
« Reply #356 on: July 11, 2023, 07:51:59 pm »
For a cascode I would consider lower threeshold devices on top. As an extra bonus one also looses less voltage. The upper one may be better outside, so the variable power from a variable votlage does not cause to much variable heat.  For a voltage reference the cascode part would be to get a higher voltage, like references in series. The drain voltage is from an amplified voltage (e.g. 1.25 x or 1.5 x).
For the oven it is not only the size that matters, but also the power of the parts in the oven. With high power there, the isolation can not be that good as one would otherwise like. For the oven design it really helps if the sensor reacts fast to the heater, possibly even faster then the actual reference part.  To avoid stress to the transistor it may not be such a good idea to glue it to the aluminum block.
Offline magic
« Reply #357 on: July 11, 2023, 08:39:49 pm »
FYI, a potential approach to combine opamp scaling with high impedance constant current output.
You would replace M1 with the JFET reference and derive VB from its source voltage.
Offline EC8010
« Reply #358 on: July 12, 2023, 08:28:12 am »
Point taken about outer device and its variable heating. I had noted that the drain voltage came from amplified reference in the same way that many linear regulators power their reference from their output.
Yes, I'm aware that the sensor needs low thermal mass and good coupling so that it accurately reflects what is going on. Also about size and power. Ultimately, there's a thermal mass whose temperature you want to change by heating, so the lower the mass, the less power needed. At the same time, there are losses to the environment, and although it would seem sensible to minimise them, they are actually needed to help in stabilising temperature, because if you apply too much heat, you want the system to cool quickly (ideally with the same time constant as for heating). Subconscious wondered about mechanical stress to the JFETs and gluing in block. I'll think about that one some more.
Later edit: Conscious has thought about it and decided that gluing JFETs into a block held at constant temperature is fine. What wouldn't be fine would be gluing them into a block that changes its temperature and has a different coefficient of expansion to the epoxy containing the silicon die, thereby applying variable stress to the silicon as temperature changes.
« Last Edit: July 12, 2023, 03:46:55 pm by EC8010 »
Offline EC8010
« Reply #359 on: July 13, 2023, 09:48:58 am »
The J112 is not that bad, mainly limited with the plastic case that can make it susceptible to humidity effects. So far my favorite is the 2N4391, as one of the cheaper ones in a metal case and relatively well available. The current (1-1.5 mA) and voltage (around 5-8 V depending on the batch) are reasonable.
Kleinstein, could you expand on your epoxy humidity comment, please? What are you suggesting, surface leakage or bulk leakage?
Online Kleinstein
« Reply #360 on: July 13, 2023, 10:34:00 am »
The weak point with a plastic case is an effect of humidity. Epoxy and many other plastics slowly take up some humidity from the air and this leads to swelling and thus a change in the mechanical stress to the part inside. The mechanical stress can effect semiconductor parts and resistors, e.g. with a change in the voltage or current. The humidity effect is usually slow, like a few days to weeks to stabilize.
Heating the parts makes the effect faster and with a higher temperature compared to the environment the rel. humidity is reduced (like half for every 10 K). For a part used intemittendly in a more humid climate this means some humidity drift after turn on.
Offline EC8010
« Reply #361 on: July 13, 2023, 10:54:28 am »
Thanks for that. I'm aware that plastics absorb water (it's why you can't make accurately dimensioned nylon parts), and the asymmetric shape of a TO92 case will apply changing stress with different absorption. Interesting. I was thinking in terms of direct electrical leakage rather than a mechanical effect. And that has an interesting knock-on...
I have previously thermally bonded TO92 devices by drilling a 4.8mm hole in 5mm thick aluminium clamped to a piece of sacrificial aluminium so that when separated, and the device is inserted, the TO92 flat face very slightly protrudes from the face. I then clamp that piece of aluminium to another and achieve a good thermal bond all round the device. But from what you've said, a better solution for long-term stability is to simply drill a complete 4.8mm hole and fill the gap with epoxy. It might not be exactly the same kind of epoxy as used by the semiconductor manufacturer, but it's a much closer humidity absorption match than aluminium. If you look at a TO92 device, the legs (and presumably die) are on the diameter of the perimeter, so returning the epoxy to a cylinder would reduce mechanical stress from absorbed humidity.
Thanks again.
« Last Edit: July 13, 2023, 11:00:13 am by EC8010 »
Offline Alex NikitinTopic starter
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #362 on: May 24, 2024, 09:00:00 pm »
For various reasons I didn't do regular measurements on my JVR unit, however it was working 24x7 all these years and now that I have a new voltmeter - HIOKI DM7275 - , here are some fresh measurements. I don't have calibration data on the HIOKI however it agrees with my other meters (two Keithley 2015 and HP3456A) and my Fluke 731B voltage reference to less than 3ppm. Last measurements made in 2016/17 at 24/25C are here in the thread. I've repeated the conditions as much as I could, with a stable 25C ambient (less than 0.2 degrees C variations). Assuming the HIOKI is reasonably accurate it appears that the JVR didn't drift much over these 7 years.
Cheers
Alex
« Last Edit: May 24, 2024, 09:05:13 pm by Alex Nikitin »
The following users thanked this post: Mickle T., exe, Gyro, 2N3055, MiDi, iMo, arcnet
    • A.N.T. Audio
« Reply #363 on: May 28, 2024, 11:44:44 am »
Here is my attempt to plot the tempco for the JVR using my small reptile box "temperature chamber" and the HIOKI DM7275. The apparent "hysteresis" is just the time lag as the speed of the temperature change is not controlled. The temperature measured on the JVR case however internally the unit is hard-wired on a perforated board and various bits warm up and cool down with different speeds. I am planning now to build an updated unit on a proper board and possibly with a temperature control and/or a parabolic temperature compensation. From the graph below it looks like the tempco can be improved several times with a good temperature sensor and a parabolic convertor. If I can flatten the curve down to, say, 0.2ppm/C (+/-2ppm over 15-35C ambient range), it would be a nice reference which would have a very low current consumption  and would require very little warm-up time.
Alex
« Last Edit: May 28, 2024, 03:50:32 pm by Alex Nikitin »
The following users thanked this post: Andreas, Gyro, 2N3055, MiDi, ch_scr, MegaVolt, iMo, Antonio90
Offline IconicPCB
« Reply #364 on: September 26, 2024, 11:31:36 pm »
Alex ,
There is a new development which could improve on the JVR idea.
Please see the attached document.
Offline ivo
« Reply #365 on: September 27, 2024, 10:10:20 am »
If I'm mathing right, the 120mA diode went from 117.5 to 115mA over 25C to 75C, so 0.05mA/C, or in relative terms -400ppm. Is that really zero? I also kinda wanted to see a tempco spec column, if thats the big feature on the product title... 25mA is also a lot of current for smaller applications
Online Kleinstein
« Reply #366 on: September 27, 2024, 02:31:01 pm »
The constant current diodes are for LED lights and similar. So low TC is relative - good for a light appliction, but not useful as a reference - not even competing with a TL431.
Still nice to have somewhat fine graded parts with not so much tolerance in the current. Still a bit on the high side for many uses. These may internally be depl. mode MOSFETs with an integrated resistor.
Offline iMo
  • Country: li
« Reply #367 on: September 27, 2024, 06:05:28 pm »
There is the Vishay Siliconix CR240 (2.4mA) current source (a jfet with a resistor) claiming typ 0ppm/K. All other CRxxx are plus minus hundreds of ppm/K..
« Last Edit: September 27, 2024, 06:08:34 pm by iMo »
Offline DeltaSigmaD
« Reply #368 on: September 20, 2026, 08:21:34 am »
Today, there are huge problems to buy highly-stable references like LTC1000x or ADR100x. So, JFET references can become an interesting alternative if higher noise in the low frequency region is acceptable.
Five years ago I assembled a 5.0V JREF reference (version JREF1) which used a  2N4416 JFET and a 2N2907 for 2nd-order temperature compensation (see posts 2021). Its drift was -29 ppm in the first year, but it was stable within 7 ppm during the next 4 years. The stability is about +/-1 ppm within a week. This 9V-battery-operated device settles to better than 1 ppm deviation within 3 min after switching it on (total consumption 2.7 mA). A 34470A DVM (100 plc) was used for the measurements.
The following users thanked this post: Andreas, splin, MiDi, ch_scr
