Author Topic: Datron Wavetek key hack  (Read 4810 times)
Offline doktor pytaTopic starter
« on: November 25, 2017, 07:30:25 pm »
Below sequence of photos showing how to hack the lock used to prevent unauthorized calibration.
It works with Datron 1271/81 but should also be suitable for most instruments with white front panel.
It is fine unless the equipment is used in student's lab.
Open the top cover to access to internal side of the rear panel.
Use screwdriver to unlock two plastic holders. Do this VERY gently not to break old material.
Use pilers to unscrew the nut.
Mark the proper position before removing the lock from the panel.
The following users thanked this post: CalMachine
Re: Datron Wavetek key hack
« Reply #1 on: November 25, 2017, 07:33:30 pm »
Remove the lock and remove securing ring. This is not so easy but can be done using one screwdriver.
Press to remove internal drum.
« Last Edit: November 25, 2017, 07:40:21 pm by doktor pyta »
« Reply #2 on: November 25, 2017, 07:35:39 pm »
Remove all springs, parts from the drum.
« Reply #3 on: November 25, 2017, 07:39:45 pm »
Mount the drum into the lock.
Insert securing metal ring. This time it's easier.
Mount the lock on the rear panel.
Attach the plastic part with the cables.
Secure using zip tie.
Finished!
Now You can use a coin, screwdriver etc. to enable calibration procedures.
« Last Edit: November 25, 2017, 07:42:18 pm by doktor pyta »
Offline rigrunner
« Reply #4 on: November 25, 2017, 07:46:46 pm »
Useful if you're in a hurry  :-+
The key is a couple of pound/dollar/euro  from RS:
Key for Operated Switch
    RS Stock No. 319-792
    Brand Lorlin
    Mfr. Part No. KEY850
https://uk.rs-online.com/web/p/key-switch-keys/0319792/
Internet of Things: A solution desperately trying to find its problem
Offline dl1640
  • Country: cn
« Reply #5 on: November 26, 2017, 01:34:37 am »
I wonder if the keys are same for these instruments?
Offline rigrunner
« Reply #6 on: November 26, 2017, 01:49:15 am »
I've purchased the key from RS and it works. I determined the part from details i got from a replacement key purchased by ManateeMafia.
As far as i'm aware all 1271 and 1281 share the same key.
Offline ManateeMafia
« Reply #7 on: November 26, 2017, 02:18:19 am »
I recently bought a 1271 and separately the manual for it. The manual came with a key and it worked in both 1281 and 1271.
Offline CalMachine
  • Metrology Nut
« Reply #8 on: November 26, 2017, 05:08:08 am »
I've got a 4708, 4808, and 1082 key.  I believe the 1082 key also works in the 1271/1281.
When I didn't have a key I just picked the lock...
All your volts are belong to me
Offline Mickle T.
  • Country: ru
« Reply #9 on: November 26, 2017, 06:10:34 am »
1071 keys also works in the 4000A, but didn't in the 1271.
Offline dl1640
  • Country: cn
« Reply #10 on: November 26, 2017, 01:24:24 pm »
interesting, i do have a 1271 key which means it can be duplicated if someone else need that key without destory the key lock:)
Offline rigrunner
« Reply #11 on: November 26, 2017, 05:12:34 pm »
The 1271 key doesn't work in my 1071 lock.
« Reply #12 on: November 26, 2017, 05:40:53 pm »
Just pick the lock, all you need are 2 paper clips to do so with these style of wafer locks.
Offline quarks
« Reply #13 on: November 26, 2017, 07:57:16 pm »
original key for 1271/1281 is LORLIN KEY850 and can be ordered here
https://www.alliedelec.com/lorlin-key850/70749334/
Offline syau
  • Country: hk
« Reply #14 on: October 25, 2018, 07:41:44 am »
I just order 2 key (minimum order qty) from RS, received it within 3 days and confirmed it work on on my 1281 as I need to change the line freq to 50Hz  :D
Offline acts238willy
« Reply #15 on: January 30, 2019, 08:58:41 pm »
How many 'master keys' are there for these locks? More than 10???
If so, I'll go with the 'pick' key...
Offline Johnny10
« Reply #16 on: January 30, 2019, 09:11:22 pm »
I need keys for 1062 LS101, 4000, 4000A.
Maybe just easier to buy new lock?
After re-reading all the above posts I am quite lost in which key works which lock.
« Last Edit: February 05, 2019, 07:27:01 pm by Johnny10 »
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
