The thermistor data is not very useful as-is and must be converted into temperature. I use downloaded thermistor tables. Over a small temperature range, I assume a linear relationship.
Hi enut
I have been messing around with ntc thermistors recently with a view to build a multichannel temperature logger
I happen to have a couple of these hanging around from vishay
https://au.element14.com/vishay/ntcle100e3333jb0/thermistor-ntc-33k-5-radial/dp/1187032I'm using labview to log data for initial tests to see what sort of resolution I can get out of these
Using the constants provided in the data sheet and the Steinhart equations also in the data sheet I seem to be getting good results
Because of the relative extreme resolution I am able to detect minute changes in temperature.
Accuracy, on the other hand is still an unknown, especially considering the formula given is more of a close fitting approximation rather than an actual measurement for the specific thermistor used.
For my purposes I am more after relative measurements over time rather than absolute accuracy
attached is the datasheet and an excel sheet with the constants for my particular thermistor along with the formula to calculate temperature in degrees celsius from the resistance
