The small size case has also some advantage getting the fet pair close together. However measuring the FETs before soldering is a bit fiddely. For a well matched pair one would need to measure quite few (like 20).
Well as a some small middle project I created a small tool for testing sot-23 transistors with ease. As shown in pictures it continues the 'metrology' tinfoil traditions. Contact surface is build with manhattan technique on cloths pin jaw, it seems to work flawlessly. It can be also used for other surface mount devices like resistor, which was my first DUT, with two different un-calibrated technologies so the non-correlation to standards can be guaranteed.
I should attend to 'Nanoamps and below like ninja' -thread with that galvanometer in Leeds & Northrup test set .. it's just crazy. Something verified with Keithley 197A Microvolt meter
Next test component was with MMBF4117 and 5$ component tester, unfortunately that JFET is just too much to tester, I need to ask about it at $5 tester thread...
I swapped to BC847C and that is in operation limits of this atmega wonder.
Last test was conducted with Meratester FET multitester, the resistance between measuring pads is over 10Gohms.
Construction is simple and by ordering gold plated PCB one can get rid of oxidation problems. That is the reason I tinned the pads, so I can remelt them easily with flux. The caps between pads are filled with cyanoacrylate (cheapest variety, wonderfull material), then swept with small wooden spatula to flush (another half of the clip). When quick glue were driedthe surface was cleaned with exacto-knife. If one needs to make temperature variation one could ie. glue a big thin SMD resistor at the another jaw and make some form of heat controller to it (I think I will do that at some point .. maybe). I can see also a future of making myself a clamp on heater for resistor selection with same type.
Hopefully this post gives some diy ideas.
edit. pictures attached with PC.
