@dietert1
Well, this experimenter did his own homework (see attached research paper and Datum's user guide for the Efratom LPRO 101 wherein they quote a rather wishy washy figure of "Altitude (operating) -200 ft. to 40,000 ft. <1E - 13/mbar").
That Swiss Lab paper had arrived at a figure of 0.8 E - 13/mbar which, since it didn't violently disagree with Datum's rather vague figure, I took as my initial starting point to compensate for this effect until I could run my own verification tests to get an actual figure for the LPRO 101 oscillators.
After figuring out a cost effective way to vacuum test one of my spare LPROs using a cheap 11 litre pressure cooker and vacuum pump, I purchased said items last February and ran my tests around the beginning of March. I eventually, after a few false starts, obtained Frequency shift delta figures of 0.607 E -13 and 0.587 E -13 per mBar on my final two test runs which I averaged to a value of 0.597 E -13/mBar to use as my barometric compensation factor.
As far as I'm aware, the caesium beam tube in these secondary caesium atomic frequency standards aren't effected by this pressure effect to anywhere near what a typical rubidium vapor lamp pumped earthbound RFS has to endure, hence my response to your statement.
[/* EDIT] Also worthy of note are the aging figures given in an entirely separate Datum datasheet (naturally!) which I've now attached which claims a 10 year figure of <1E -9 which, as best as I can figure it would by now correspond to a daily aging rate somewhere in the region of 1 to 2ns rather than your suggested figure of 43ns a day.
[*/ EDIT]
