Author Topic: Fluke 5700A fans  (Read 2321 times)
Offline jfphpTopic starter
Fluke 5700A fans
« on: December 18, 2019, 04:11:40 pm »
I am looking for the manufacturer and part number of the fans in a 5700A first generation (unable to find in the parts section of the repair manual !). Thank you.
Offline Ice-Tea
    • Freelance Hardware Engineer
Re: Fluke 5700A fans
« Reply #1 on: December 18, 2019, 04:13:42 pm »
Should be listed on the fan itself, no?
« Reply #2 on: December 18, 2019, 05:46:50 pm »
Of course no in my case, that is why the question...
Offline Ice-Tea
« Reply #3 on: December 18, 2019, 07:48:26 pm »
No markings at all? Not even embossed in the plastic? Anyways, fans have pretty standardized dimensions. Measure diameter and voltage and it should be easy enough to find something..
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #4 on: December 19, 2019, 04:37:04 am »
There is a pic with fan label on Todd's 5700A repair article. I tend to replace fans with slightly faster/noisier fans to get unit more comfortable. Fans, capacitors, carbon resistors replacement are just go to procedure on any expensive R&M device older than 10 years. Relays are consumables as well for stuff like scanners/calibrators, and so on.  ;)
« Last Edit: December 20, 2019, 02:36:29 am by TiN »
Offline SometimestheDragonWins
« Reply #5 on: December 29, 2019, 07:28:47 pm »
Ill go open up mine and check it out, give me an hour or so and ill be back
