Yes that's the unknown measured by the 53131A Ed. I used the defaults in the [Timelab] Acquire screen. I'll try starting it again and check... still learning this software but it's really nice for free! I'll check the Frequency vs. Time Interval. I assumed since it supported the 53131 that it would configure it for the sampling?
No, the author decided not to do any configuration. Timelab just accepts data. You have to tell it what the data is. Considering Timelab's price (free!), I'm not complaining.
Which is better way to measure frequency or time interval? I suppose both give you information but they correlate correct?
Frequency and Time Interval (phase) are two sides of the same coin. You can convert phase to frequency with no issues, but there are some problems going the other way. When it comes to measuring ADEV, there are a few differences. Most notable is the difference in slope of the resulting graph. In your graph, it takes about two decades of frequency for the graph to drop one decade in ADEV, i.e. the slope is -0.5. If you measure Time Interval, the slope is -1 which causes the graph to drop faster. This gets you into the low values that we're really interested in sooner. I've seen graphs of OCXOs that didn't look impressive because the measurements were frequency based and by the time the graph got down to the good stuff, the crystal aging was already causing the results to rise.
The reason for the difference in slope is hidden in the fog of theory. The value of the slopes suggests that it's related to different types of noise. The slope of -1 suggest white or flicker phase noise while -0.5 suggests white frequency noise. I don't know why the different measurements would exhibit different types of noise. I'm more of an application guy.
Ok much better now here's the comparison with both Rb measured by 53131.
Yes, much better. But you you might be able to do even better. You should measure the noise floor of your 53131 to see if it's working up to spec and to see what results you can expect from it. This measurement is for Time Interval. I don't know if the noise floor in frequency mode is the same or not. That's a question for the theory guys.
All you need for this test are two pieces of BNC cable and a BNC T adapter. Connect the T adapter to Channel 1. Set the impedance of Channel 1 to 1M ohm. Connect a BNC cable from one side of the T adapter to Channel 2. Make sure the cable can't flop around and make sure that the temperature won't change during the test. The length doesn't matter. A meter or two is fine. Set the impedance of Channel 2 to 50 ohm. Feed a square wave from your 8040 to the open connector on the T adapter. I think the 8040 has a 1 PPS output. That would be perfect. Set the triggering on both channels appropriately for the input signal. Now measure Time Interval and collect the data with Timelab. Since there's nothing between Channel 1 and 2 but a piece of cable, the delay should be very stable. Any variation will be due to noise or limitations inside the counter. The resulting ADEV graph will show you the best results you'll ever see from that counter.
A good rule of thumb is that the ADEV @ 1 sec. should be about the same as the minimum time interval resolution of the counter. For the 53131A, that would be about 5e-10 @ 1 sec. Since most good quality counters exceed their specs, you might do a bit better.
If your results are
much better than spec, it means your counter is making multiple measurements and averaging them. You have to disable that 'feature' before
any of your measurements will make sense. If your results are much worse than spec, you may have a setting wrong on your counter or a fault in your counter or your 8040.
This isn't a long test. If you watch the ADEV graph as the data is being collected, you'll see that the 1 sec. value flops around to begin with, but stabilizes within a few minutes. You can stop the test there. Sometime when it's convenient, you can let the test run longer to see how far down you can go. Eventually, the graph will become a flat, horizontal line, but that's usually so far down that there isn't any point in measuring it.
Ed
