https://insidegnss.com/update-galileo-service-degraded-on-all-satellites-precise-timing-facility-problems-cited/
The outage is being attributed to problems at the Precise Timing Facility in Italy.
Who cares... Post Halloween the UK will be out and will Germany be able to justify the project?
People use Galileo?
Quote from: EEVblog on July 15, 2019, 09:33:47 amPeople use Galileo? Cant hesitate to state obvious: yes they do, usually w/o even knowing that. Now there are >795m devices with seamless multi-constellation support. The more satellites you can receive - the better positioning performance/resolution. It's also good in case one of the systems goes down
My Huawei phone only has GPS and GLASNOSS.
Quote from: EEVblog on July 15, 2019, 10:45:25 amMy Huawei phone only has GPS and GLASNOSS.Then your phone most likely is older than few years. Also not in this list (currently 145 phones): https://www.usegalileo.eu/EN/inner.html#data=smartphone. BTW Huawei P30 have dual frequency receiver
And what if Iranian subversive military cells, for example, do terrorist attacks on your ground Precise Timing Facilities in Fucino and Oberpfaffenhofen? @NATO
It's a Mate 20It's in the list but I see no option for Galileo in the software
Supposedly there is a backup timing facility in Germany... oops... this saga just gets better...
