That gives me about 30ns error in-line with the RMS error. The other 30ns (to make 60ns) must be occasional internal artifacts or poor GPS satellite locations? Does this sound about right? And what about that last 1%?
Hi.
Yes, I agree with you about the 30ns RMS error.
No idea what they are trying to say with the 99% 60ns
As thinkfat said, try to make your design as thermally stable as you can.
When testing, put the whole thing in the final case with lid on, this will give you accurate thermal effects.
Normally, you would leave the ocxo on for at least an hour to warm up and thermally stableize.
From my understanding, normally your would use averaging over long periods (hours) to compensate for the 1pps gitter. Thermal effects are relatively slow (multiple or even ten minutes), the Oven Controlled part is meant to increase this further to multiple tens of minutes (after the warm up time). So after an hour, you can start to work out the ocxo thermak drift but the gps jitter may not be averaged out with only 1 hour, it may take multiple hours to do that.
