Hi, gang,
Jr. metrology questions...
I am a ham experimenter with an age old conundrum: Now that I have a GPSDO (or some other high-order standard), how do I know whether it's accurate and working normally? If I connect the GPSDO output to a counter, the counter will have to be at least as accurate as the GPSDO to determine anything useful, right?
And what if I discipline the counter and then use the same counter to measure the GPSDO output? Is that a thing?
I also have a "new" (old stock) reference oscillator from the former AADE (ham radio cottage industry). It's never been powered up until a week ago and is about 6-7 years old. The builder says that the TCXO he used, which was calibrated before delivery to his NIST-traceable gear (and one in which he has used hundreds of times in his line of frequency displays), historically drifts/ages about 6 Hz over six years at 10 MHz. If I compare the output of the GPSDO to that of the TCXO, they outta be quite close -- but without a known comparison I will have to "assume" that the GPSDO, when locked, is the one that's on the money?
Attention mega-metrologists: I know that the TCXO is a low-cost trinket, so remain calm.
If I can receive it well, WWV is always there. I read years ago about a way to graphically calibrate signal sources by using a PC-based audio spectrum analyzer (SPECTRAN?) to plot WWV vs the unknown source on the waterfall while using WWV's 1000-Hz tones to guarantee a certain precision when tuning the signal. This should get me to about 0.5 Hz at 10 MHz, which is probably fine for anything I anticipate doing in the near future.
But it's an interesting conundrum! A chicken-egg metrology thing!
Also: I have about 3,000 feet of high-quality RG-6 coax. The kind with a solid copper center conductor and not copper-clad steel. I want to use this to make some BNC lab jumpers until I make some up "proper" cables. I assume this will work fine for distributing the 10-MHz ref signal from the GPSDO, but I suspect that many purists would liken that to genocide... Any real issues with using the 75-ohm stuff to get started?
More: I am also trying to learn the proper way to measure the output power of the GPSDO and the ref oscillator. I may need to terminate my scope with a 50-ohm load to get proper V readings. And I haven't yet had the courage to connect either to my spectrum analyzer, as I need to build/acquire a tap or an attenuator.
I have a 1975 HP 5328A counter. It has an internal TCXO/OCXO that seems to be nearly dead-on for a nearly 50-year-old device, as it counts the GPSDO output to many decimal places (undisciplined it thinks the GPSDO output is about 85 Hz low). It doesn't have either of its prescaler options, so right now it tops out at 100 MHz.
I don't yet know the impedance of the counter's 10-MHz external reference port, nor the recommended signal level. Gotta find out before connecting GPSDO?
I don't want to fall down this rabbit hole too far. I have no need for pico-hertz precision I just want to learn a bit about this stuff and how to use it to make my test bench more accurate in very reasonable ways. I had fun (?) learning the basics of using Lady Heather. At present I build stuff mostly for HF, with a bit of 6 and 2 meters thrown in for good measure. If my counter is off by 1 Hz at 30 MHz, no prob. I just wanna know.
As always, thanks,
--Kirk, NT0Z
My book, "Stealth Amateur Radio," is now available from
www.stealthamateur.com and on the Amazon Kindle (soon)
