Hello Metrology
New to eevblog, last few days reading vref posts, and I don't have a question. Searched and found nothing so here goes. It seems as if humidity in a sealed, hopefully hermetic, reference could/should be a problem with some devices. I had planned to build a LM399 ref to avoid some of that but remembered a material used for a similar purpose. The 4A molecular sieve binds water vapor, some gases and hydrocarbons but is shipped in sealed 2 #, and larger, jugs and does not implode so should be safe. MSDS should be studied and maybe even a test in the proposed container, without ref, but it is cheap, available, and fast. Can be dryed out at 250-450 F depending on RH and amount of H2O absorbed.
