Author Topic: Investigation on ...  (Read 12756 times)
Offline branadicTopic starter
  • Sounds like noise
« on: December 02, 2016, 08:05:33 pm »
This thread is about the investigation on ... :-//
Well, no words about it yet.  It's up to your guess. Here are the first pictures of some parts a friend of mine currently fabricates for this project. The next pictures will follow soon and after a while you will get an idea of what this will end up in.  :-+
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
Re: Investigation on ...
« Reply #1 on: December 02, 2016, 08:09:46 pm »
 Waveguides ?
Avid Rabid Hobbyist
Online 2N3055
  • Country: hr
« Reply #2 on: December 02, 2016, 08:48:59 pm »
Either resonant cavity or oven...
Offline Andreas
« Reply #3 on: December 02, 2016, 09:03:43 pm »
Hello,
looks more like one of those zero ohms resistors or a 4 wire shunt.
with best regards
Andreas
Offline Gyro
« Reply #4 on: December 02, 2016, 09:04:45 pm »
Hmmm,
It's in the metrology section, high thermal mass enclosure, structurally stable..... Resistance standards?  No fixing holes on the top surface though and they look finished. Something potted?  Strange if so.  :-\
Best Regards, Chris
Offline Theboel
  • Country: id
« Reply #5 on: December 02, 2016, 11:51:23 pm »
I bet its a resistance standard  8)
Offline VintageNut
« Reply #6 on: December 03, 2016, 02:59:08 pm »
+1    Metrology individual resistors look similar to this.
working instruments :Keithley 260,261,2750,7708, 2000 (calibrated), 2015, 236, 237, 238, 147, 220,  Rigol DG1032  PAR Model 128 Lock-In amplifier, Fluke 332A, Gen Res 4107 KVD, 4107D KVD, Fluke 731B X2 (calibrated), Fluke 5450A (calibrated)
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #7 on: December 03, 2016, 05:03:27 pm »
Resistor tempco test boxes? :)
I'm gonna build some too, as my current TEC jig used for LTZ reference module test is just too painfully slow for TCR test.
Offline Gyro
« Reply #8 on: December 03, 2016, 06:19:18 pm »
Come on branadic, give us a break - is there some kind of lid???
Best Regards, Chris
Offline ManateeMafia
« Reply #9 on: December 03, 2016, 06:48:57 pm »
My guess is that they will laser weld the lids and install kovar leads or some hermetic connector out of the sides.
  • Sounds like noise
« Reply #10 on: December 03, 2016, 07:43:04 pm »
There is a lid on top and some feedthrough capacitors at the sides.
Offline mimmus78
« Reply #11 on: December 03, 2016, 07:48:04 pm »
Too much pieces for a simple investigation ...
Inviato dal mio Nexus 6P utilizzando Tapatalk
Offline tatus1969
  • Resistance is futile - We Are The Watt.
    • keenlab
« Reply #12 on: December 03, 2016, 08:19:30 pm »
RF directional coupler for a VNA...
« Last Edit: December 03, 2016, 08:21:29 pm by tatus1969 »
We Are The Watt - Resistance Is Futile!
Offline kxenos
  • Country: gr
« Reply #13 on: December 03, 2016, 08:55:34 pm »
I would guess voltage reference using low noise chinese zeners or oil filled resistors
Offline acbern
« Reply #14 on: December 03, 2016, 08:58:21 pm »
hermetic resistance?
Offline manganin
« Reply #15 on: December 03, 2016, 09:10:27 pm »
If you look closely there seems to be a naked bulk metal foil resistor inside the box.
Online 2N3055
  • Country: hr
« Reply #16 on: December 03, 2016, 09:18:41 pm »
4w for resistor, and 2 for thermistor or RTD....
hm...
Offline manganin
« Reply #17 on: December 03, 2016, 09:34:38 pm »
Worth noting that the 4-wire feedthrough for the main resistor is actually not necessary. Simply calculate how much the very short resistor copper wires affect the total temperature coefficient.
The SR104 uses 2-wire feedthrough but there is also 15 cm 2-wire cabling from the feedthrough to the binding posts (2w/4w interchangeability was important at the time it was designed).
Offline KerryW
« Reply #18 on: December 03, 2016, 09:40:31 pm »
Copper chips?
One accurate measurement is worth a thousand expert opinions
- Adm. Grace Hopper
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #19 on: December 04, 2016, 04:54:16 am »
I'd buy few samples of such neat boxes for my unhappy foils  :-+
  • Sounds like noise
« Reply #20 on: December 04, 2016, 09:43:01 am »
Good observation  :-+
Yes, it is a hermetic case for Vishay VAR resistors in 4W connection and an additional PT1000, using PCap01 a like chips to measure and digitize temperature. The case will be filled with Galden, to avoid humidity effects. The lid is soldered to the bottom part.
It's just to find out how Vishay VAR can perform. Because at the institute I work for our main topic is packaging of integrated circuits. What I've learned so far is, that every highend sensor can perform bad if package and assembly is bad. So take the naked part, use an adequate packaging technology and the part will perform much better.
Offline Andreas
« Reply #21 on: December 04, 2016, 10:47:13 am »
Hello branadic,
one question arises to me.
Does Galden expand with temperature?
How is the relation of the expansion coefficient against the housing.
Or is there some pressure relief planned?
With best regards
Andreas
  • Sounds like noise
« Reply #22 on: December 04, 2016, 10:54:47 am »
I plan to use something like LS230, so no big deal within normal operation.
Offline Theboel
  • Country: id
« Reply #23 on: December 04, 2016, 11:22:59 am »
Hi Branadic.
Could you consider to use more sensor like BME280
So you can measure humidity and pressure
Offline acbern
« Reply #24 on: December 04, 2016, 11:38:13 am »
why galden? just because its handy? I would think others such as fluorinert or silicone transformer oil (ok, soldering issues, but thats after the fact anyway) are more itended for that purpose, and partly also show higher insulation resistance. I do not know galden very well, other than its used for VPS, maybe you can give us some details why you selected it.
