Hello,
i have mounted the scope at the entrance of the adc, there was an oscilation of about 50mv ( unfortunatly i did not found the stick to export the scope's picture).
I removed the 4n7 capacitor, and the oscilation disapeard.
Everything seems to work fine now.
By the way, can you recomend some low ripple power supplies for negative/positive rails?
In my design i use XC6210B332MR for the 3v3 rail, and LTC1550LCMS8-2 for the negative voltage.
