no offense but you have very cheap low cost voltmeters who will do what you need at better resolutions and portability ?
i know you want to do your own things, but parts, time and design ... it will not be an economical solution
7106 7107 are way outdated, and now mostly used in volt or amps panel meters, even now, more modern mcu's will do better
7107 needed a +5vdc and a -5 vdc supply, or even used some oscillator tricks to get negative voltage from a single 5vdc, or used some 7660 ic to generate it
the 10 Meg input impedance is mostly done by the voltage divider resistor network, you add all of them and you have your 10 megs
the basic designs of a 710x is 1 meg with some added capacitance on input + you will never get the 10 megs of impedance ....
you add the decimal point selector and the range divider for 200mv or 2v scale that's all,
you add other stuff / functions with other parts, alone the 710x are not ohms meters ... they are 1999 count voltmeters
