Author Topic: MTD415 - a low cost, RS232-controllable, bipolar 1,5A TEC controller-module  (Read 4857 times)
Offline Echo88Topic starter
As voltnuts we sometimes need very stable thermal conditions or want to test the TC of whatever component, so maybe the following is helpful for you guys:
In my search for a reasonable cost TEC controller i came across the MTD415-module, which is at the moment for sale at Thorlabs.
They are nifty little RS232-controllable +-1,5A bipolar TEC-drivers with onboard digital PID-controller.
So i bought one to test it (an MTD415T for 10k NTC sensors) and was satisfied with its stated performance. I achieved about 10mK stability (like advertised) in an less than optimal thermal setup.
Much better stability wont be achievable i think, because of the inherent low adc-resolution and the TEC-current resolution, but i might be wrong.
In comparison to the usual small bipolar TEC-drivers/controllers (LTC1923, ADN8831, Analog Technologies TEC controllers) this solution is, in my opinion, remarkable because of the simple PID-control: no resistors/caps to change while finding the perfect PID-parameters, just change the parameters of anything via RS232. With about 24€ its about as cheap as a LTC1923/ADN8831-solution (including the necessary pcb) and way cheaper than the controller from Analog Technologies. Of course the MTD415 cant temp-stabilise an object as good as the other aforementioned analog solutions, but most of the time one doesnt need 1mK stability.
Links:
https://www.thorlabs.de/newgrouppage9.cfm?objectgroup_id=10626
http://shop.analogtechnologies.com/TEC-Controllers_c6.htm
Im not affiliated with Thorlabs and just wanted to share my findings with you, maybe someone can use this module in an interesting project.
Greetings,
Echo
Edit: Added a photo of the interior. Datasheets for two recognized ICs:
https://www.diodes.com/assets/Datasheets/AUR9718B.pdf
https://www.silabs.com/documents/public/data-sheets/efm8bb2-datasheet.pdf
« Last Edit: July 24, 2017, 07:44:33 am by Echo88 »
The following users thanked this post: ramon
Offline Andreas
Hello,
Photos of your setup?
Did you only measure the temperature sensor (directly at the TEC) or some components more far on the PCB?
But on the other side: a 5V 1.5A TEC is shurely only intended to cool single chips.
With best regards
Andreas
I have already disassembled the structure; basically it was just a CPU-heatsink with fan, a suitable TEC and a about 100x80x10 mm aluminium block on top of the TEC, which was covered with paper to avoid air drafts. A 10k NTC sitting, thermally coupled with thermal paste, in a bore directly in the middle of the aluminium block was measuring the temperature.
