I'm going to make a Voltage Reference based on SATURATED standard cells -- have a couple of TRANSVOLT 9154D boxes with 4 saturated standard cells in Dewars, all 8 cells are still alive and have proper EMF. I'm going to redo the heating -- have proper calibrated tools to measure (and set) temperature to 0.001 degrees Celsius (or Kelvin
) so the EMF can be calculated and it is supposed to give an absolute value to be used as a PRIMARY standard.
I want to BUFFER/amplify the cells' EMF with LT1012A opamps and looking into their datasheets makes me scratch my head.
They have the "Saturated Standard Cell Amplifier" example in several of their datasheets (LT1008, LT1012 and some others) that uses their beloved 2N3609 FET to disconnect the cell when the thing is powered off. It is a verbatim copy in ALL of them and I can't understand how they thought it should work.
The 2N3609 is a dual P-CHANNEL FET with substrate pin and unprotected gate. The closest replacement is [also unobtanium] MFE3020 but it doesn't need to be a DUAL so 3N163/164 can be used as a replacement. Those were resurrected by Linear Systems and readily available from major distributors. I'm going to keep the buffers/amplifiers OFF most of the time, only powering them ON couple of days before using that Frankenstein for calibration and then power them off thus keeping the cells disconnected most of the time.
The problem is it is NOT going to work as shown. It is a P-CHANNEL FET so applying a POSITIVE potential to its gate will NOT make it conduct. As shown, it requires a comparable N-CHANNEL FET but there is nothing comparable to those 3N163s in N-Channel. Linear Systems has 3N170/171 that are closest to 3N163 in N-Channel but those have 50 times the 3N163 drain-source leakage in OFF state (10nA vs 200pA) and their threshold voltage might be too low. Nothing else like that is available anymore even if it existed back in the dark ages.
Does anybody know what they thought when they included that very same example in their multiple datasheets?
BTW, NSC also have an example of a Saturated Standard Cell Amplifier in their LM11 datasheet but that one is significantly different although they used the same 2N3609 FET (they use two of them so dual makes sense there). However, they used it PROPERLY -- substrate to positive rail, gate to negative, and the cell's NEGATIVE lead is switched by the 2N3609 channel.
