Right...
All my posts are carefully considered believe it or not, shocked was/is the right word.
You keep asking why the resistance at 1-1 is different from 2-2/3-3 for some reason, it doesn't matter what it is at 1-1, you can make it anything you want because the lugs are not measuring there. But..
The only way to measure resistance is to force a known steady current between 2 carefully selected points and then measure how much force(voltage) was needed to do it. The more force(voltage) that was needed the higher the resistance is.
When you force this known steady current though 1-1 or 2-2 the current
If you could see the current flowing between 2 points on a surface it would look more like this. shunt2.jpg
Most of the current total flows directly through the middle line between the 2 points, but there are smaller currents taking longer curved paths, each side of the center line, and even smaller currents flowing all over the place. If you need a very accurate measurement, then all these smaller currents add up to quite a few % of the total current.
Drawing these currents on your shunts would look vaguely like this. shunt3.jpg
Right away, hopefully, you can see that some of the lower parts of the 1-1's current paths are missing - cut off, by the cutout, compared with 2-2. So when you come to force the steady known current between 1-1 it takes a bit more force(voltage) to get it to flow though the paths which are still there. And of course this bit of more force means 1-1 has a bit more resistance.
If you moved points 1-1 down towards the bottom edge even slightly, then more of 1-1's current paths would be missing, and show up as more resistance. If you moved points 1-1 up a bit it would give 1-1 more current paths and less resistance, you'll get a different resistance nearly every time.
The 4 wire measurement bit to avoid all these errors has already been done.. and done, so just do it for now.
All this won't be 100%, but close enough for me!
