Hi group,
I am sharing the design and build of a 10V battery powered reference based on the LT1021-10. This is a DMM-check level of reference. I wanted something that I could take to a meter, instead of taking the meter to the calibrator.
Inspiration
This application circuit from the datasheet shows the LT1021 being used in shunt mode. The circuit can be modified to the positive version.
This application circuit shows how to implement a restricted range trim circuit.
Schematic
This is the schematic. The current source is implemented using a green LED and and BJT. The forward voltage of the green LED is around 2.2V. Minus the Vbe of Q1, 0.7V, results in 1.5V across the 510
resistor. This results in a 3mA current source.
PCBThe PCB was designed using KICAD version 5.
Build
A 3D-printed base was attached to the PCB.
Testing
The trimmer was adjusted for 10.000V
This is not the world's best reference, but it can be used for checking DMM's on the 10V. It is relatively easy to build.
Regards,
Jay_Diddy_B
