Hello my friend,
I had the T3 transformer repaired and tried the device again, but my problem continues. This error really made me tired. If I can't find a solution after looking for a few more days, I will give up.
As soon as I turn the device on, my -15, +15, 5V regulate ICs and Q16, Q17 MOSFETs get hot. (Q12, Q14 transcitors heat up a little slower).
Although there are no short circuits and all my regulated voltages are stable, I don't understand why they are getting hot.
I removed U1 and when I turned the device on, my mosfets and transistors were cold, but my regulate integrated circuits still got hotter than normal.
By the way, I compared it with the 5500A A8 card, yes there are differences, but I saw that the pin sockets were the same at least up to the point I checked, at least it shouldn't cause it to heat up like this.
I think the 5520A A8 card can work with 5500A.
Because this card was inserted before the device broke.
