Author Topic: Symmetricom S200 Teardown/upgrade to S250  (Read 104539 times)
Offline robertps88
  • Country: id
Re: Symmetricom S200 Teardown/upgrade to S250
« Reply #200 on: January 20, 2026, 12:06:13 pm »
Did you manage to solve this, mine is doing the exact same thing, tried clean cf, and dd ed ones, serial is nothing, the rxd indicator on my serial to usb adapter is blinkinf though, i am trying another thing which is the RAM, maybe it failed during moving the boot files from cf to ram. But finding those ddr1 is not easy. Any thoughts anyone?
Offline Astralix
  • Country: at
« Reply #201 on: January 29, 2026, 12:02:23 pm »
The unit has arrived at the new location, in a box with lots of other network equipment. But construction work is still in progress, so no chance to disassemble the thing and poke around. I also tried to get a second unit, but either none available that fits the one I have or at ridiculous prices, at least for a unit that will get disassembled and analyzed.
So in w few weeks, when the lab is up and running, I'll poke into it.
Offline drhex
« Reply #202 on: January 29, 2026, 12:14:08 pm »
A chap called Alex Forencich (not sure if he's on here) apparently managed to patch the firmware of the GPS module to work around the week overflow. I found the attached .sx (just remove .hex extension) which I can open in Ghidra as Motorola HC12 file. This is where my knowledge ends though, analysis doesn't really give me things to try - anybody here wiser on HC12 and willing to have a look? May be good enough to inject the modified file into the upgrade package linked in the thread above to get it to install...
Offline Astralix
  • Country: at
« Reply #203 on: January 29, 2026, 12:34:25 pm »
Oh, nice one! That would fix the GPS boards. Too late for me as I bought two replacements (one was stolen but never compensated, because it was deposited before and not behind the front door. Thanks DPD!)
However flashing the HC12 by hand and then having a replacement board is also nice, or just using it for something different.
Offline drhex
« Reply #204 on: January 29, 2026, 04:44:19 pm »
Hmmm, there even is a flash tool. Wondering if this is for the main board though as there are references to DCF77 in what I linked earlier.
Offline drhex
« Reply #205 on: January 30, 2026, 02:18:47 pm »
Strangely, mine locks on GPS without any patching?
Offline drhex
« Reply #206 on: January 30, 2026, 08:14:42 pm »
But not consistently, falls back to NTP from time to time. Seems to be related to the number of satellites it finds.
Offline ATK
« Reply #207 on: February 02, 2026, 09:58:30 pm »
I've been following this thread for a while, and just ended up getting an S250 with the Rubidium clock from the factory. It was sold as for parts since it was hanging on OS load. I was expecting to find an X72 lamp clock inside of it, but instead it has an SA.33m MAC (!). An interesting note is that even without the OS, the rubidium seems to free-run just fine. The PLL lock diagnostic light on the motherboard comes on (but does not if powered up without the SA.33m plugged in), and I get a very stable 10MHz out. I've not tried any disciplining without an OS, but I'd expect that not to work.
I'm quite happy with all of that, but am curious if anyone has an image for a CF card for a unit this late. The motherboard is an 87-6107R-1 Rev. G. The SA.33m is on a carrier PCB with a P/N of 066-00338-000. Rev. D.
I need to buy a CF card now, but am curious about getting it to boot from a SATA drive. There is a video header on this motherboard, so I may investigate that as well.
Offline drhex
« Reply #208 on: February 19, 2026, 07:55:26 pm »
For anyone adding the rubidium oscillator to a S350: Jumper J3 needs to be in else it won't be recognized. I have a few adapter boards in case someone wants some - need a bit of work with a file to make the screw holes fit properly as my guesswork was slightly off. Work well otherwise.
Also caved in and bought a Heol module to get GPS working - works well in Survey and Dynamic but shows no satellites in position hold. Hope they can fix that.
Offline richcj10
« Reply #209 on: Yesterday at 07:34:50 pm »
What adapter boards do you have?
Has anyone loaded linux on this and used as that? I have a OXCO mod on my S250.
Offline Astralix
  • Country: at
« Reply #210 on: Yesterday at 09:21:36 pm »
Loading Linux on it? The original system runs on Linux already. We were discussing about using a more modern Linux or updating some very vulnerable services around the http server in it.
However, I don't think that is an issue if the clock runs on your internal network without permissions to talk to it from the outer world.
