The top is pretty clearly a different piece, and it will have had to be held on somehow. Not only that, but (almost certainly) it has to be a method accessible from the outside, so if it's soldered, you should be able to see some clues - soldering is never quite that perfect.
Unless... the bottom comes off. More pictures would be helpful! But just continuing to look and think, looking for tiny clues, might yield your answers.
I'm kind curious about that screw on top. None of my Leeds and Northrup or Honeywell resistors have such a screw. Ground lug? Structural? Pressure thing? Hm.
It is kinda pretty, though! Is that gold paint?
