I am making a TAPR TICC and TADD2-mini combination unit.
TADD2-mini allows output to be synchronized with external standard. Say there is a 10MHz coming in. TADD makes it into 1pps. If there is another pps connected (say from GPS) it can synchronize with that. As I understand it, this happen once only. Next count is on its own without syncing.
I could, for example, sync it with reference input, or sync it with second TADD2-mini. Either way, two signal will start exactly in sync first then let it drift.
What I am not sure is, with TICC, is it even necessary?
Does anyone think there will be a need for it?
My current plan
2 TADD2-minis. In and out connector on front panel. 1/2.5/5/10MHz selector on front panel. 1 pps LED on front panel.
1 PICC. In connector on front panel. "now measuring A" and "now measuring B" LED on front panel. Reference input, on front panel. (no internal reference) USB on front panel. I am not quite sure why I need the LED... doesn't "reading" happen simultaneously? Are there a mode that I'm not aware of where counting happens only on one or alternately?
I don't plan to make this into a Swiss army knife. Flexible to a degree but nothing more.
Opinions and Ideas, please.
