I didn't see any particular problem with the SVT and my 3455A- the results agreed with the Fluke 845A and the 3478A and the three 731s, just with less resolution. The last digit of the 3455A will wander a couple counts. I don't have the data logging set up for the 3455A, but that would be the smart thing to do. Too many projects, too little time. The problem with my other 3455A seems to occur with any voltage source, so I'm assuming it's inherent in the unit. It's not a huge amount, just a few counts, but too much for my OCD. I don't remember there being any adjustment to trim it out, so one might have to select components or something.
The whole shielding/guarding thing has pitfalls. That's why I used a wall wart and the regulator board to power the SVT, as I don't know the ground isolation of my big bench supplies. It's the current paths you don't know that will throw things off. On that note, last night I did a run comparing two of my 731s. A couple periods of maybe 5-15 minutes had 1/4 ppm steps I need to track down. It could have been air currents on the connections, or even popcorn type noise in a reference. The trials and tribulations of a voltnutter.
