Author Topic: what is the deal with DC shorts and offset  (Read 11524 times)
Offline mendip_discovery
Re: what is the deal with DC shorts and offset
« Reply #50 on: July 18, 2026, 09:39:50 am »
To ensure the rather expensive accessory you bought is only used on the right machine and the right way up, and isn't plugged into the rather expensive calibrator, etc.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Online Kean
    • Kean Electronics
« Reply #51 on: July 18, 2026, 10:58:45 am »
Sounds reasonable, but I suspect the connector housing was just designed to be general purpose and so it also incorporated the current input.
It does have a hole for a cable to exit, although that is normally covered by the name plate.
Offline laichh
  • Country: my
« Reply #52 on: July 20, 2026, 03:15:45 am »
It is for current measurement, indicated by the letter next to the pin.
Online Kean
    • Kean Electronics
« Reply #53 on: July 20, 2026, 03:25:45 am »
Well not when it is built as a 34172A/B which is purely intended as a calibration short.
As I mention the connector housing was likely also intended for other purposes, and thus they labelled the 5th pin as "I" to match the current input.
Maybe someone has seen a cable from HPAK using this as a connector?
Offline laichh
  • Country: my
« Reply #54 on: July 20, 2026, 09:02:18 am »
If you observe carefully, the 34172A/B is essentially a sticker covering the recessed text [34171A/B] & the hole in the middle. Removing the sticker will reveal the text & hole hiding below it.
Online KungFuJosh
  • TEAS is real.
« Reply #55 on: July 28, 2026, 12:50:31 am »
So the extra pin is a training wheel for idiots?
Best Continuity Tester Ever
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #56 on: July 28, 2026, 03:51:39 am »
Don't worry, a better idiot is already being worked on to mitigate this interference. :-DD
In reality, I'd say it's easier and cheaper production and inventory-wise to just use the same underlying part.
