Author Topic: [Bitcloud] End device sleeping  (Read 3087 times)
Offline danergo2Topic starter
  • Country: hu
« on: April 20, 2016, 04:52:56 pm »
Hi guys,
I have a fairly simply question to you this time.
I'd like to make an end device with bitcloud, because this time my device needs to be battery-powered.
So I compile everything onto that, and it works okay.
However, I have some buttons in the project which obviously needs to wake up the micro. However its INT pins were needed for something else.
So I solved this by adding an AppTimer, which polls the buttons in every 50 ms, so it's very usable at this way, however:
1.) Does the micro tries to rejoin the network each time, when the apptimer wakes it up?
1.a) If yes, how can I control it to not waking up each time, but only each minute, or so?
1.b) If no, why not?
Thank you very much.
Danergo
Offline ataradov
    • Personal site
Re: [Bitcloud] End device sleeping
« Reply #1 on: April 20, 2016, 08:08:18 pm »
If you are using a reasonably new version of the BitCloud, then it will sleep most of the time and wake up on interrupts.
But if you do explicit sleep request, then device will go into deeper sleep mode, but in this mode it will only wake up on true external interrupts or sleep timer. In this case your software timers will not run.
When your software timer callback is called, device is not really fully sleeping. It wakes up every 10 ms to run software timers.
Device does not rejoin every time. It has to wake up every CS_END_DEVICE_SLEEP_TIME ms. There is a software timer just like yours that will take care of this.
Alex
  • Country: hu
« Reply #2 on: April 21, 2016, 09:24:28 am »
Thank you!
I'm using a 3.2.0 right now. Is it new enough? In this case, if I don't do explicit sleep request, device will sleep when it can, and wakes up for my AppTimers (and interrupts, etc), and after CS_END_DEVICE_SLEEP_TIME ms it will try rejoining to network?
So,
SYS_EnableSleepWhenIdle
is not the explicit sleep request, and
ZDO_SleepReq
is the explicit one?
Offline ataradov
    • Personal site
« Reply #3 on: April 21, 2016, 04:16:18 pm »
Yes, anything that has SYS_EnableSleepWhenIdle() is new enough.
Correct.
No rejoining is necessary, device will just poll the parent to indicate that it is still there.
Correct.
With SYS_EnableSleepWhenIdle() your system will wake up every 10 ms because all software timers are running from a single 10 ms hardware timer.
Alex
  • Country: hu
« Reply #4 on: April 21, 2016, 08:35:24 pm »
Thank you very much!
