Author Topic: [BitCloud] End device StartNetworkReq  (Read 2070 times)
Offline danergoTopic starter
  • Country: hu
« on: May 06, 2016, 06:42:34 am »
Hi!
I'm doing now some test on my network with one ED and a C.
ED is polling periodically C to check if the connection is still alive or not.
If I stop the C (unpower it), ED receives ZDO_NETWORK_LOST_STATUS through ZDO_MgmtNwkUpdateNotf. That's great.
However when I restart the C (power it again, so it starts from scratch), ED is just don't want to realise it. In spite of my app (ED) constantly trying to ZDO_StartNetworkReq if the state is APP_STARTING_NETWORK_STATE (exactly like in WSNDemo). I waited 10 minutes, and nothing happened. CS_END_DEVICE_SLEEP_PERIOD is 60000.
If I reinit the ED with
PDS_DeleteAll(false);
HAL_WarmReset();
it can start the network succesfully.
What would be nice to check for investigate this one?
Thanks!
Offline ataradov
    • Personal site
Re: [BitCloud] End device StartNetworkReq
« Reply #1 on: May 06, 2016, 06:58:06 am »
You need to wait for ZDO_NETWORK_LEFT_STATUS. ZDO_NETWORK_LOST_STATUS is just a notification that network is lost and stack will attempt to fix stuff. But technically (all the internal states) stack is still in the network.
I'm also pretty sure that ZDO_StartNetworkReq() in that case will return ZDO_INVALID_REQUEST or similar error code.
Alex
  • Country: hu
« Reply #2 on: May 06, 2016, 07:26:05 am »
I see. Thank you.
So it's a very bad design idea from me to use ZDO_StartNetworkReq right after ZDO_NETWORK_LOST_STATUS.
2 questions remained:
1.) if I call ZDO_StartNetworkReq when ZDO_NETWORK_LOST_STATUS is received, is it possible that I prevent the stack to gracefully leave the network and reinit it? (It seems)
2.) The right way seems to do nothing when ZDO_NETWORK_LOST_STATUS is received but wait for ZDO_NETWORK_LEFT_STATUS. Can I be sure that after getting LOST status, also LEFT_STATUS will arrive sooner or later?
Thank you
Offline ataradov
    • Personal site
« Reply #3 on: May 06, 2016, 07:31:18 am »
I'd need to check the code, but again, I'm pretty sure that ZDO_StartNetworkReq() will be confirmed with an error code and nothing bad will happen, stack will continue doing what it was doing, and ZDO_NETWORK_LEFT_STATUS will be called eventually.
Yes, 100%.
And if you are absolutely don't want to wait, there is ZDO_ResetNetworkReq(). That will bring everything into initial state no matter what stack is doing at the moment. But there should be no reason to use this at all.
Alex
  • Country: hu
« Reply #4 on: May 06, 2016, 07:35:42 am »
Thank you.
I'm totally okay with waiting after ZDO_NETWORK_LOST_STATUS.
