Author Topic: [Stm32 Cube IDE] Programming without debugging?  (Read 2360 times)
Offline kgavionicsTopic starter
« on: May 03, 2023, 07:38:50 pm »
Hello guys
I just switched from Keil uvision to STM32 CUBE IDE which has a simple option to program the MCU in very fast way , without debugging as opposed to Cube which launch a debugging session that takes about 1 min before it uploads the hex file to the MCU. .My question: Is there any option to for uploading the hex file without debugging in Stm32 Cube?
TIA
Offline langwadt
Re: [Stm32 Cube IDE] Programming without debugging?
« Reply #1 on: May 03, 2023, 08:01:29 pm »
1 minute?
The following users thanked this post: cfbsoftware
Online DavidAlfa
« Reply #2 on: May 03, 2023, 10:02:25 pm »
Use "run" instead debug?
Offline Siwastaja
« Reply #3 on: May 04, 2023, 05:09:18 am »
Install openocd, run from command line, takes only seconds (although understanding how to use it would take a few hours first).
Offline nctnico
« Reply #4 on: May 04, 2023, 11:29:36 am »
Hello guys
TIA
Disable auto-build before starting a run / debugging session. You can find this in the run / debug configuration setting.
