Author Topic: 6 channel rc controller algorithm  (Read 2991 times)
Offline sfiberTopic starter
  • Country: tr
« on: June 26, 2014, 09:07:28 am »
hi my friends,I couldnt developed algorithm about pwm peak values.as you know when you move joystick of 6 channel rc controller it controls servos but when you pull your hands from joystick it doesnt move to middle position like joystick.If you want to make your servo to middle position you have to pull joystick opposite side.can anyone help me     about algorithm.
I use stm32f4.
Online Psi
Re: 6 channel rc controller algorithm
« Reply #1 on: June 26, 2014, 09:13:01 am »
A RC controller has a spring which returns to center.
It sounds like your issue is to do with relative vs absolute position.
Relative position means the new servo position is calculated from it's current position.
Absolute position means the position is a mirror.  70% joystick = 70% servo position.
« Last Edit: June 26, 2014, 09:19:45 am by Psi »
  • Country: tr
« Reply #2 on: June 26, 2014, 09:20:58 am »
but servos dont move like joystick,they stays them peak values.
Online Psi
« Reply #3 on: June 26, 2014, 10:13:51 am »
im not sure what you mean by peak values?
Offline dannyf
« Reply #4 on: June 26, 2014, 11:24:22 am »
That's one hell of a sentence to understand, :)
I think what you want to achieve - there is a high likelihood that I am wrong on this - is what people call incremental PID.
A simpler way to achieve that is to calculate the pwm on the delta of two variables: joystick's current position, and joystick's decayed position.
Something like this may work:
  js_cur = joystick_read(); //read joystick's current position
  js_dcy+= (js_cur - js_dcy) * alpha; //revise js_decay to approach js_cur, alpha determines the speed of decay
  js_pwm = f(js_cur - js_dcy); //generate pwm based on the difference between js_cur and js_dcy
Right after you have moved the joystick, js_pwm takes the highest value. After that, js_dcy starts to approaching js_cur and the pwm value starts to decline until the js_cur/js_dcy are sufficiently close.
Essentially it is an auto-centering algorithm.
You will need to figure out how to handle the negative values when generating pwm.
