Ghidra does really well for 8051 disassembly, but it's pretty complicated and the help/tutorials are aimed more at modern 32bit processors with high level languages. Ghidra does have a 8051 emulator included, but documentation is poor and the processor model doesn't correctly handle some of the weird 8051 instructions (like modifying a register by using a pointer to the memory mapped register shadow location).
As a quick start for running Ghidra under windows, try:
- download latest version from
https://github.com/NationalSecurityAgency/ghidra/releases- follow installation (aka unzip) instructions, you'll also need a JDK but don't need the python stuff for basic operations
- go to the ghidra directory and double click on ghidraRun.bat
- create a new project under your documents\ directory, or wherever you like
- under File, select ImportFile, point it to your .bin file, and select the language (8085, or the 8051 default/default version)
- double click on the .bin file to launch the CodeBrowser tool
- say Yes to the auto-analyze prompt and use the default selections
- click on code line 0000 (the 8031 reset vector) then type a "d" to disassemble
- click on the other main 8031 vectors (0003,000b,0013,001b,0023,002b) and type a "d". If it doesn't look like reasonable assembly code, do a <Ctrl-Z> to undo
- to save an ascii listing, select File-->ExportProgram, select Ascii, point it to your desired directory, click OK
Example results for your 290078 8031.bin file are attached.
