Author Topic: 89c51 non-isp programmer  (Read 6732 times)
Offline AlanaTopic starter
« on: February 17, 2013, 06:32:50 pm »
I'd be glad for links and recommendations for 8051 series programmer. I have several of older non-isp chips around and i would like to play with them again. I have programmer for 89c51 and 89cx051 [20pin version] but this is parallel port based and in my new lappy there is no LPT.
I'd strongly prefer DIY version - i propably have all the parts but i do not have money.
Offline westfw
Re: 89c51 non-isp programmer
« Reply #1 on: February 18, 2013, 03:14:46 am »
Well, it would certainly be easiest to start with some other microcontroller; preferably something with a lot of pins that was itself easily programmable with a modern computer (or perhaps you could borrow a computer with a parallel port for long enough to program an 89c51 to make a programmer from?)  An Arduino MEGA or Sanguino would probably be a good starting point.
I have some 89c51s too; just connecting all those wires seems like a major PITA compared to a modern serial-programmable controller. :-(  Mine are LQFP, so just popping them into a socket doesn't seem likely, either.  Sigh.
Offline westfw
« Reply #2 on: February 18, 2013, 10:01:49 am »
« Reply #3 on: February 18, 2013, 10:30:59 am »
Problem is that pc software for it is not available on project's webpage.
Offline amyk
« Reply #4 on: February 18, 2013, 02:07:18 pm »
http://chaokhun.kmitl.ac.th/~kswichit/ez4/ez4.html
The slight issue is that the programmer itself needs an 89C51 to be programmed... maybe then you'd have to "bootstrap" via DIP switches and pushbuttons?
« Reply #5 on: February 18, 2013, 02:25:55 pm »
Those designs are OK and i do have means of programing bin/hex into 89c51 but there is an issue with PC software - i checked out all those programmers on this webpage and the only pc software that is still there is for LPT version.
Offline notsob
« Reply #6 on: February 18, 2013, 09:19:43 pm »
As you said price was an issue, these are probably not for you but have a look anyway.
http://www.mikroe.com/8051/development-boards/
http://www.mikroe.com/8051/programmers-debuggers/
Notice that the\ey also use the Silabs programmer/debugger   http://www.silabs.com/products/mcu/udp/Pages/UDP-debug-adapter.aspx
