Author Topic: ADC 7921  (Read 1163 times)
Offline lorenrusTopic starter
ADC 7921
« on: July 24, 2020, 08:44:45 am »
Hello everyone
I have to use ADC AD7921.
It is manageable through the SPI device. It is equipped with two analog inputs that can be selected by manipulating a MUX, through SPI.
By default, the Vin0 signal is enabled on the exit from the MUX, which I read correctly with the code I attach.
One thing I noticed is that if I decrease the freq I read incorrect values, and this thing is not clear to me since on the datasheet, p. 7, I find a Freq rage from 10 khz to 5 Mhz. What am I wrong?
Further, he goes to sample in and out on the fall.
On my uC which is a SAMD21 I selected mode 3.
The data that he sends me I receive correctly with mode 3 because, even looking at the time digram, page 7, he samples the DOUT on the falling and I on the uC I read it on the first positive front.
But instead when I send from the uC, always with mode 3, they field on the FALLING and also the ADC on the DIN samples on the FALLING. Could that be the problem?
I attach the code separately to send the channel value.
Ulteriore cosa è che guardando il diagramma temporale di pagina 8 si vede che richiede 16 colpi di clock per eseguire tutta la comunicazione; come faccio a far risultare esattamente questo numero di colpi di clock ?
Thank you
SPISettings SPI_Settings_Test_14(5000000, MSBFIRST, SPI_MODE3);
void setup() {
     Serial.begin(115200);
void loop() {
                   // SPI ACTIVED
                    SPI.begin();
                    // BUS SPI ACTIVED
                    SPI.beginTransaction(SPI_Settings_Test_14);
                    //  SLAVE ACTIVED
                    digitalWrite(FPGA_CS_VOLT_NEG, LOW);
                    SPI_Received_Value_BATT_480_VOLT = SPI.transfer16(0);
                    // SLAVE DISABLED
                    digitalWrite(FPGA_CS_VOLT_NEG, HIGH);
                    Serial.println(SPI_Received_Value_BATT_480_VOLT, BIN);
                    // BUS SPI DISABLED
                    SPI.endTransaction();
                    // SPI
                    SPI.end();
                    float Voltage = SPI_Received_Value_BATT_480_VOLT * (5.2/4096);
// SEND DATA -- CHANNEL VALUE
                    // ABILITO LA COMUNICAZIIONE SPI
                    SPI.begin();
                    // ABILITO IL BUS SPI
                    // ATTIVO LO SLAVE
                    SPI.transfer16(001000000000000); pag 17
                    // DISATTIVO LO SLAVE
                    SPI.end();
