Author Topic: Looking for MOTOROLA AN-853 Application Note - 6805 Emulator Design  (Read 2537 times)
Offline marcopoloTopic starter
Hello,
I'm looking for the MOTOROLA application note AN-853 for the 6805 MCU
Topics covered:
- M146805 Emulator Design Considerations
- ROM Emulation
- I/O Emulation
- Interrupt Emulation
- Oscillator emulation
- MC146805G2 emulator example
- ROM Emulation
- I/O emulation
Emulation is discussed briefly in the User's Manual 2ed.
If you have:
- Documents on the 6805 and 68705 not available on Internet
- Emulator/Simulator informations or software
- Assist05 source not available on Internet
- M68705EVM Schematic
- MC146805E2 Evaluation board schematic
I'm also interested in  :)
Thanks,
Marc
« Last Edit: August 25, 2024, 03:36:39 pm by marcopolo »
Offline DiTBho
Re: Looking for MOTOROLA AN-853 Application Note - M146805 Emulator Design
« Reply #1 on: August 25, 2024, 01:12:48 pm »
Similar problem for M-Core.
I had to buy paper-books and paper-ANs, because I was unable to find any digital copy.
It seems like everything before 2000 was on paper and Motorola didn't always pay someone, likely part-time students, to scan documents  :-//
« Reply #2 on: August 25, 2024, 03:24:48 pm »
I've also had the same problem with some ECL application notes  :(
For old logic circuits (RTL, DTL, ECL), MC68xx and 68K, I archive everything by topic here: https://marc.retronik.fr
Next month, I'm starting up my scanner again (CANON A3 with 500-sheet feeders).
if any of you want to send me (in France) documents to scan on the above subjects, you're welcome to do so.
It's a one-way trip, I'll cut the documents for the ADF.
The following users thanked this post: edavid, 2N3055
Offline SCSKITS
  • Retired electrical engineer
Re: Looking for MOTOROLA AN-853 Application Note - 6805 Emulator Design
« Reply #3 on: September 09, 2024, 03:54:45 pm »
I have a PDF of AN-853 and the Errata.
Contact me off list and I will send the PDF.
ed
scskits at charter dot net
SCS, DIY upgrades for older test equipment
The following users thanked this post: marcopolo
« Reply #4 on: September 09, 2024, 04:09:01 pm »
Email sent!
Thanks.
Offline MathWizard
« Reply #6 on: September 27, 2024, 04:04:07 pm »
So that's for using other MCU's, is emulate other ones ?? I figured it was going to be computer software emulation, but yeah a PCB and a few parts can do it...
I just downloaded a few CPU/MCU emulators, like one for the Z80. I need to read a pile just to get anywhere in the program tho. I want to find a simple 4 or 8-bit MCU emulator, with just some buttons and lights, and opcodes.
Offline Benta
« Reply #7 on: September 27, 2024, 08:02:58 pm »
I think you're confusing emulators with simulators.
A simulator is a piece of software that illustrates the behavious of the CPU/MCU.
An emulator is a piece of hardware with a target cable that plugs into the socket where the CPU/MCU normally sits in your system. It's able to emulate the the hardware behaviour of the chip in real time, and control all memory, peripherals etc. in the target system.
Offline westfw
« Reply #8 on: September 30, 2024, 08:31:25 pm »
Ah, "temporal context"!
in the timeframe of the 6805, an "emulator" was typically a RAM-based, PC-controllable/loadable device that would plug into the target socket, but be "more easily" programmed (especially with targets that were ROM-only.  But this was before flash/eeprom, and even UVEPROM-based chips were rare, expensive, and slow.)  They also might provide better monitoring of useful debugging signals (like decoding the address bus to implement some sort of hardware breakpoint or code tracing.)
Sometimes the manufacturer would have, or provide, other versions of the chip with external buses (as appears to be the case here) and/or extra pins, or even full-fledged (and expensive) box-level products with proprietary internals and fancy debuggers.  But as high-speed, high-density RAM became more available, you could find self-built "ROM Emulator" projects in the hobbyist community as well.  (For example: https://hackaday.io/project/175610-rom-emulator )
