I wonder if anyone here uses Nuvoton MCUs for anything? I'm specifically interested in ARM, but any other would work too for information.
There seem to be no information about them on forums and they are not the name that comes up first in searches. So, I wanted to see if anyone uses/used them for anything hobby or work related.
A couple years ago I was searching for a small pin count MCU with USB HS device controller and integrated PHY. It is not easy to find devices like this from common well known vendors and when you do the price starts from $12.
So, back then I started looking for all sorts of off-beat stuff and found Nuvoton. They basically had the perfect device for what I needed - M484SIDAE (192 MHz Cortex-M4F) and the price was unmatched ($3.5 small quantity).
They also have NUC505DLA, which is slightly slower Cortex-M4 device, but still with USB HS. And at even cheaper price.
And they also had a promotion at a time where you get 90% off your first 5 samples of any 5 devices (25 ICs total). I ordered a bunch of different devices and the total was $12 including shipping
Back then I made a simple breakout board for M484SIDAE, made a basic project and never got around to USB stuff. Well, this weekend the time to play with USB came, so I made a port of Free-DAP to that device (
https://github.com/ataradov/free-dap/tree/master/platform/m484).
Based on that I have mixed feelings. The documentation is interesting. It is very bare, like there is no way a novice would be able to figure anything out. I had no serios issues, although at times I wished there was more information. The whole description of the USB HS Device peripheral is literally 2 pages (excluding register bits). I was able to figure it out, but mostly because I programmed a lot of much worse stuff before. And unlike with common vendors, finding information on the web is impossible. There is literally nothing.
The hardware is well designed. I have some basic complaints, but overall it is much better than a lot of stuff from mainstream vendors.
During the past couple years I checked their store and the devices I was interested in stayed available all the time. I guess partially due to relative obscurity.
Yesterday I placed a bigger order and the price was actually cheaper than 2 years ago when I got samples.
So, yes, if anyone had any experience with them, I'd like to hear. And if not - check them out. They might work for you, especially given the current situation.
